The DTC Disable thread (P1235, P1241, P1238, etc)
Old Dec 29, 2009 | 11:33 AM
  #256
ITP's Avatar
ITP
Any more info on P0140? The last thread on that went dead sometime ago. I'm sure there are still plenty of people that would like the info on this.
Old Jan 1, 2010 | 10:37 PM
  #257
nj1266's Avatar
Originally Posted by FTY Motorsports
i know what happened now simple stupid mistake lol that is why i test it on my cars and not customers
Did you get a chance to test the code on a 2010 Evo X yet? Has anyone tried it yet to see if what SiC posted works?
TIA
Old Jan 1, 2010 | 11:46 PM
  #258
criptballer's Avatar
Originally Posted by itp
any more info on p0140? The last thread on that went dead sometime ago. I'm sure there are still plenty of people that would like the info on this.
+1
Old Jan 8, 2010 | 05:23 AM
  #259
Noize's Avatar
EvoM Administrator
Real short drive, DTC disable seems to work good.
Quick question, though. This will not effect the readiness of my OBDII system, right? Like I can pass emissions no problem?
Old Jan 21, 2010 | 10:47 PM
  #260
tephra's Avatar
P0140/P0139
if anyone is game - you can try setting 0x503B2 to 0.
thats 1 byte, not 2byte - so scaling is uint8...
thats ONLY for 526800XX
THE DEFAULT SHOULD be 1, SO STOP STOP STOP if its NOT NOT NOT
Old Jan 22, 2010 | 05:58 AM
  #261
xPRimNT's Avatar
Originally Posted by tephra
P0140/P0139
I'll test tonight.
Old Jan 22, 2010 | 07:57 AM
  #262
Guru's Avatar
ooh will test this weekend. I'm using plx wideband tapped into secondary o2 wiring, is this the only code i have left to turn off the cel? been so long since i scanned the car
Old Jan 22, 2010 | 03:13 PM
  #263
tephra's Avatar
when testing make sure your tune doesn't change
Old Jan 22, 2010 | 06:14 PM
  #264
Guru's Avatar
Is it under ECU options or do I have to add lines to the misc section of the xml file?
Old Jan 22, 2010 | 06:16 PM
  #265
tephra's Avatar
u will need to add a 1D table.. use uint8 scaling...
Old Jan 22, 2010 | 09:02 PM
  #266
xPRimNT's Avatar
Well, I won't be able to test until Monday, but I definitely will. Is there anything I should look out for? You mention the tune "changing", but what is likely to change if anything?
Old Jan 22, 2010 | 09:04 PM
  #267
xPRimNT's Avatar
In ECUFlash, right click the Maps in a ROM and choose New Map. Then pick the 52680015 tab, select 1D table and make sure scaling is uint8. Everything else should be fairly self explanatory.
Old Jan 25, 2010 | 09:35 AM
  #268
Guru's Avatar
First time I tried, it didn't show up. Kinda worried I may have entered in something I can not see. Second time worked just fine.
Old Jan 25, 2010 | 09:39 AM
  #269
Guru's Avatar
I only see one extra line of code correctly in the 52680015 XML file.
Old Jan 25, 2010 | 09:41 AM
  #270
Guru's Avatar
Hmm wait I see an extra line in the 52680018 xml file. Should I delete? This is what it says.
<table name="O2code" address="503b2" scaling="uint8"/>
I actually named it O2sensorcode the second time I did it successfully
Oh and now both things are showing under misc.
