The DTC Disable thread (P1235, P1241, P1238, etc)
Old Feb 3, 2010 | 04:14 PM
  #316
Huge's Avatar
Originally Posted by tephra
thats weird.
you sure you flashed the right ROM?
Ill try it again tonight. I'm also going to unplug the o2 sensor and see if that helps.
Old Feb 3, 2010 | 06:51 PM
  #317
Huge's Avatar
OK, I checked to see if I had flashed the correct ROM and I also check for the code one more time.
I was mistaken I thought I saw the p0420 code this afternoon, but it was really the P0140 - 02 Sensor Circuit No Activity Detected
I've checked and rechecked to make sure I disabled what I was supposed to correctly, I'm out of ideas.
Old Feb 3, 2010 | 06:54 PM
  #318
tephra's Avatar
You MUST clear the code after doing the disable mod...
Let me know if it comes _back_ after that
Old Feb 3, 2010 | 07:13 PM
  #319
Huge's Avatar
I did clear the code 3 days ago when I first did the disable mod. It seams I have not popped the p0420 but now I get the P0140 which I never had before the disable mod. which leads me to think I did something wrong during the disabling process.
Ill flash the ecu one more time and clear all codes and get back to you.
Old Feb 3, 2010 | 07:16 PM
  #320
tephra's Avatar
You will get P0420 when you havn't done the ECU_OPTIONS_2 bit1 = 0
once you do that you will then get P0140.
you then need todo the P0139/P0140 disable to get rid of that code.
Old Feb 3, 2010 | 07:23 PM
  #321
Huge's Avatar
the first thing I did was = 0x0 for the P0139/P0140
I sent you my ROM
Old Feb 3, 2010 | 07:27 PM
  #322
tephra's Avatar
yep i got it...
i'll wait to see your results for clearing the code and driving around for a bit
Old Feb 5, 2010 | 06:00 PM
  #323
Huge's Avatar
yep i got it...
OK, two days and 35 miles later and still not light woo hoo.
Old Feb 8, 2010 | 02:48 PM
  #324
Huge's Avatar
Turned the car on today and the light was back. P0140 - 02 Sensor Circuit No Activity Detected.
Old Feb 8, 2010 | 04:40 PM
  #325
tephra's Avatar
cripballer is testing a theory this DTC disable ONLY works for 52680020.
52680015 was his, yours is 52680018.
maybe the people that report its ok have widebands plugged into rear02, hence they have activity...
i will do some more research when I have a moment
Old Feb 8, 2010 | 04:47 PM
  #326
xPRimNT's Avatar
^ Agreed.
As I mentioned before, the disable worked for me but I have 0139 due to having a WB input into the rear O2 ADC. Verkion as well (IIRC).
Old Feb 8, 2010 | 05:01 PM
  #327
tephra's Avatar
ok so that DTC is only for P0139...
just gotta find P0140 :P hehe
Old Feb 10, 2010 | 08:56 AM
  #328
20valves20lbs's Avatar
New USDM Evo X MR rom
Here is the download link to the new rom I came across. 2010 USDM EVO X MR
http://www.mediafire.com/file/aodmznymj2m/2010 USDM EVO X MR 55580005.hex
Looks like we need xml, mode23 and dtc disables.........Thank you
Old Feb 10, 2010 | 10:37 AM
  #329
GST Motorsports's Avatar
Here you go:
http://norcalmotorsports.org/users/b...0/55580005.xml
Mode 23 is incorrect so DO NOT USE IT currently. Hoping Tephra can find those addresses for us
- Bryan
Old Feb 10, 2010 | 05:29 PM
  #330
Thank Tephra:
55580005
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f107" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8ad43" type="1D" scaling="Hex8"/>
<table name="DoMode 0x4D -> 0x5D" category="Misc" address="8ad4a" type="1D" scaling="Hex16"/>
