The DTC Disable thread (P1235, P1241, P1238, etc)
Old Feb 11, 2010 | 08:35 AM
  #331
20valves20lbs's Avatar
Any way someone can define the upper and lower bound Ignition timing tables for us lowly 91 octane guys on this 55580005 rom? Tried using the currently available code but its not quite right for this rom. Thank you.
Old Feb 11, 2010 | 10:40 AM
  #332
GST Motorsports's Avatar
Updated in this thread, first post, thank Tephra.
https://www.evolutionm.net/forums/ev...wer-bound.html
- Bryan
Old Feb 13, 2010 | 10:37 AM
  #333
No MIVEC tables
The MIVEC tables seem to be missing on the 55580005 xml you gave. Any way to define those? Tried the other MR addresses but again those too are slightly off. ty
I also tried flashing on a alternate MR rom (52690021 or 0019) and it fails saying that I am trying to make changes to protected areas and terminates the flash. odd I can only reflash car with the 5558005 file.
Old Feb 13, 2010 | 10:48 AM
  #334
Guru's Avatar
I have 52680018 and so far so good. no CEL. Wife taking the X for hour long ride so we'll see if it stays off the whole time. I did have P0038 in there prior to clearing codes. Odd.
Old Feb 13, 2010 | 03:18 PM
  #335
tephra's Avatar
u got a wideband or other sensor plugged into the rear02?
Old Feb 14, 2010 | 02:11 PM
  #336
Guru's Avatar
Yes I do. PLX wideband wired in and works fantastic through Evoscan. She drive over 100 miles and no codes at all! Woot!
Old Feb 14, 2010 | 05:16 PM
  #337
nj1266's Avatar
Did anyone test the DTC disable codes for the USDM 2010 Evo X GSR?
Here is the code:
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="633e8" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="633de" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549f8" type="1D" scaling="Hex16"/>
<table name="DTC P1233 Disable 0x0028 -> 0xFFFF" category="Misc" address="549f4" type="1D" scaling="Hex16"/>
<table name="DTC P1234 Disable 0x0028 -> 0xFFFF" category="Misc" address="549f6" type="1D" scaling="Hex16"/>
I checked page 1 and did not see it added to the list yet.
Old Feb 14, 2010 | 05:19 PM
  #338
Here is the code:
Yup they work, post #288/289
- Bryan
Old Feb 14, 2010 | 06:20 PM
  #339
nj1266's Avatar
- Bryan
Thanks Bryan and Diirk. I did not keep track of the thread.
Tephra, could you please update page one and add the code for the 2010 USDM GSR to it?
Why is this thread NOT a sticky
Old Feb 14, 2010 | 06:49 PM
  #340
tephra's Avatar
whatromid?
Old Feb 15, 2010 | 02:34 PM
  #341
nj1266's Avatar
55570005
Old Feb 15, 2010 | 04:15 PM
  #342
tephra's Avatar
added.
need a mod to clean this thread up a bit
Old Feb 15, 2010 | 05:32 PM
  #343
criptballer's Avatar
if i had one wish, it would be to get rid of P0140 from the entire world. matter fact, i would make it so the combination of letters and numbers of P0140 could not ever be used in this world for anything in any sequence.
Old Feb 15, 2010 | 05:45 PM
  #344
xPRimNT's Avatar
Haha, if it bothers you that much, hook up your Wideband into the Rear O2. The fix works for P0139!
Old Feb 15, 2010 | 05:53 PM
  #345
you mean hook up my white cable to the yellow cable of the oem connector? i looked at doing that, but they said it wasn't a for sure fix. is it?
