The DTC Disable thread (P1235, P1241, P1238, etc)
Does the WOT trim disable also work for the 09 Ralliart? I copied the code into the RA xml file and got the same numbers/table as that for the Evo X. Just want confirmation that it works. Please tell me. Thanks
NJ - probably.
easiest way to test is log MUT50 and do the mod. if MUT50 drops to 0% when in the right load then you know its worked.
ps - the other thread is probably better to use
KOTT - The first 2 look ok, send me the ROM and i'll find the others as well..
ps. sorry for not answering your other post, i haven't been on this thread for a bit.
I'm a little over 50 miles so I'm crossing my fingers, I dint want to post that it worked on my car until I was sure.
IN order to do this mod I just followed xprimts thread, Its very easy to follow here is the link
https://www.evolutionm.net/forums/ev...ut-serial.html
Just extend your white wire from your aem gauge and splice it into the yellow rear 02 sensors plug under the passenger seat. Oh and make sure you remove your rear o2 sensor.
