The DTC Disable thread (P1235, P1241, P1238, etc)
Old Mar 11, 2012 | 07:27 PM
  #496
murlo26's Avatar
Originally Posted by hotstix
Can we disable p0300 and p0219?
x2 on the p0300.
Many of us with built motors have it, but seems to actually just be from clutch chatter typically.
I wouldn't mind seeing this go. We'd still have the individual cylinder codes anyway.
Old Mar 11, 2012 | 08:52 PM
  #497
hotstix's Avatar
Originally Posted by murlo26
x2 on the p0300.
Yah the p0300 is annoying. First time it was caused by my POS 1st gen DW1300s, now im 99% sure its my POS lightweight flywheel. IF there is one regret in my build its the lighweight flywheel. Should have just resurfaced the stocker, much more DD friendly.
And P0219 is an issue for 2010 and up ( I think) with built motors. The ECU doesnt like it when I rev to 8200....
Old Mar 11, 2012 | 08:58 PM
  #498
hotstix's Avatar
Originally Posted by momostallion
EDIT: i just noticed your signature. you have a lot of work done so this may not even get close to applying to your situation but:
p0300 is multiple misfire. did you do anything to change the ignition system?
p0219 is engine over speed. was there a mis shift/over rev?
the ecu presenting both of those codes in combination would lead me to believe the motor over-revved (p0219) and there could be valve damage (presented as misfiring in p0300).
https://www.evolutionm.net/forums/ev...de-help-3.html
The p0219 code will trip if the motor revs to 8k (on a 2010+). Its a permanent DTC and could be serious if your motor is stock, but my motor and head are fully built. revving past 8k isnt an issue, but the ECU doesnt know that.
p0300 is random misfire code, but like I said, I have seen this from a faulty set of DWs and now am seeing it again, which I believe is a result of my lightweight flywheel (just noise).
A misfire code is really only a cause for concern if its cylinder specific.
Old Mar 11, 2012 | 09:09 PM
  #499
momostallion's Avatar
yea, as soon as i read your signature i figured the built motor was responsible for the codes. 8k rpm. that's awesome.
Old Mar 11, 2012 | 09:21 PM
  #500
hotstix's Avatar
8k is actually pretty mild, Im on a stroker, so we kept the revs pretty conservative. My setup is good to 8500 max. But there are big bore 2.2s out there revving to 9 or even 9.5K. THATS moving.
Old Mar 11, 2012 | 10:59 PM
  #501
RazorLab's Avatar
I guess that doesn't exist on the 2008's as I have one revving to 9.5k+ with no P0219.
Old Mar 11, 2012 | 11:40 PM
  #502
hotstix's Avatar
Yah, AFAIK its 2010 and up
Old Mar 24, 2012 | 03:13 PM
  #503
Russs's Avatar
I'm getting p1235, 1238, 1241 and ASC faults on 53040007 but don't know how to enter the changes,
Can someone help please?
Old Mar 24, 2012 | 05:45 PM
  #504
tephra's Avatar
upgrade to 53040010
Old Mar 25, 2012 | 04:52 AM
  #505
Russs's Avatar
Originally Posted by tephra
upgrade to 53040010
Thanks
Does 53040010 already have those codes disabled?
Where can I find a trustworthy rom and xml please?
Happy to donate
Old Mar 26, 2012 | 08:20 AM
  #506
Golden's Avatar
You will still have to disable the codes. They are in the definition files.
Tephra's donation address is in his sig.
Old Mar 26, 2012 | 08:57 AM
  #507
Russs's Avatar
Sorted, thank you
Old Mar 29, 2012 | 07:09 PM
  #508
AWDralliart09's Avatar
Does the rear o2 patch exist for 53600010 ... I was about to tap my wide band then stopped because I couldn't find the patch for the CEL.
Thank you
Old Mar 29, 2012 | 07:48 PM
  #509
03chi-town0Z's Avatar
AWD, I got my OBD pin-8 logging working on the standalone just a couple days ago and it's well worth it (and much less work than the rear o2 tap, imo) now if only I could find a way to get that into EvoScan. I know most of the addresses transfer directly and you just change the "0x" to "23", but since the paramid=8 for the adc logging on standalone, I can't just put "8" in the request id when adding a new data item in EvoScan, right? Still new to this and oh-so lost.
Old Mar 29, 2012 | 08:11 PM
  #510
richardjh's Avatar
Nah, you're not lost. Pin 8 ADC is only accessible via standalone logging... for now.
If I want to log AFR from EvoScan, I just plug in my LC-1 via serial-USB digital link. When I unplug the laptop, standalone logging kicks in via LC1 analogue -> pin 8.
Several of us have raised a change request thingumy with EvoScan, asking for it to support OP2.0's direct-voltage-ADC logging. One day!
Rich
