The DTC Disable thread (P1235, P1241, P1238, etc)
Here's an odd question I'm not sure if anyone has asked before. It looks like the way this disable works is by setting the time before triggering the CEL to the max possible (0xFFFF -> 65535 ms).
Instead of completely disabling the CEL, can I adjust the time to double the stock time to trigger? For example, P1238 is set to 900 ms (0x0384). Can I just change the value to 1800 ms (0x0708)? Would this work?
Has anyone tried this? It shouldn't cause any weird issues should it?
It looks like you may have to do the same thing the 2008's had to do.
In addition to the p0139, the bit, you also will probably have to do this:
I believe Golden has this is defined on Goldens site, so if you use his xml, just update it. Donating while you're there isn't a bad idea either.
Code:
<table name="DTC P0140 Disable 1500 -> 8000 0xygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2)" address="539ce" category="Misc" type="1D" scaling="RPMStatLimit"/>
Anyone know how to turn off P0140 on a USDM 2012 Evo X. It is not defined in Golden's ROMs. It is only defined up to 2010 Evos. I tried copying the xml code from a 2010 to a 2012 but the before numbers did not match what I was supposed to get. There must be a different address for the p0140 code on the 2012 Evos. Anyone know it?
TIA
TIA
hi, help please
i tuned for first time a lancer Gt Cvt ecu id 52180008 with turbo kit of evo x and i have the error p1235 and p1241
Please help for eraser this DTC
And the other problem is my definition pass to load of 100 to 260, and between no have data for change.
this car is good run but with the error is limp mode
please
my email is rogerpizarro@gmail.com
please
