The DTC Disable thread (P1235, P1241, P1238, etc)
Old Nov 16, 2009 | 08:10 PM
  #196
Clipse3GT's Avatar
Originally Posted by FTY Motorsports
i have to bring up my laptop to see what the values were that were in there before but i put the addresses in and pulled up the table and changed them like it said in the first post and now im kinda stuck i can't flash anything in to the ecu or anything kinda worried right now lol. thats y i usually let others be test dummies for this stuff i thought i would try to help out now im screwed lol
Originally Posted by TEPHRA
If it don't work then:
1) When a flash craps out half way through:
a) DO NOT TURN THE CAR OFF
b) YOU CAN RESTART THE LAPTOP
c) TRY REFLASHING
2) If you did a) above then (until Colby fixes the inbuilt recovery mode) you need to bench your ECU - Basically:
Use http://www.roadraceengineering.com/e...-ecuwiring.htm as a reference
Looks like you need to hook up:
Power/Grounds:
73 = +12v?
81 = ground
82 = +12v?
93 = ground
104 = +12v?
Just ensure the "power pins" have +12v and the continutity between the ground pins and chassis is 0ohms:
To OBD connector:
90 = CANH
91 = CANL
80 = Kline
103 = pin 8 or 12 ???
If in doubt I would start by measuring the voltage output on the pins you will be "emulating". And also measuring the continuity between the OBD and ECU harness for the OBD connections.
Old Nov 16, 2009 | 08:30 PM
  #197
FTY Motorsports's Avatar
its a dealership car so cant i use the mitsu scan tool and flash it back to stock?
Old Nov 16, 2009 | 08:32 PM
  #198
Clipse3GT's Avatar
You bricked a car at the dealership???
Old Nov 16, 2009 | 09:34 PM
  #199
lol its my demo car it belongs to the dealer i use it to show off all the parts and stuff to people buying cars test drives take it to shows etc. so its not a big deal right now kinda freaked me out at first lol but if i use the mitsu scan tool thing here at the dealer can we unlock it?
Old Nov 16, 2009 | 11:12 PM
  #200
GST Motorsports's Avatar
Originally Posted by GST Motorsports
You put that in the XML or the actual ecuflash input boxes?
Did it show these in the input boxes before:
0384
03E8
0026
0028
0028
so?
Old Nov 17, 2009 | 12:50 AM
  #201
SiC's Avatar
SiC
so?
When using the addresses I posted for the 2010, it does show the correct numbers.
Old Nov 17, 2009 | 03:18 AM
  #202
so y is my **** trippin then?
Old Nov 17, 2009 | 03:53 AM
  #203
SiC's Avatar
SiC
1. The 2010 ROM uses different methods to disable the codes
2. You may have input the addresses incorrectly in the XML
3. You may have input the wrong figures in the ROM itself
4. An error occured while flashing
If you're anywhere near hbspeed, Jon should be able to help you unbrick the ECU.
Old Nov 17, 2009 | 10:11 AM
  #204
i used these addresses
633E8
633DE
549F8
549F4
549F6
0384
03E8
0026
0028
0028
I guess I'll ask for the third time?
  #205
awesome my luck then i'll give him a call today i guess
Old Nov 17, 2009 | 10:12 AM
  #206
yes the correct values popped up and i changed them per post 1 idk wtf happened.
Old Nov 17, 2009 | 03:40 PM
  #207
tephra's Avatar
email me the ROM
Old Nov 17, 2009 | 04:43 PM
  #208
sent
Old Nov 17, 2009 | 04:54 PM
  #209
tephra's Avatar
ok this rom still has the defaults for these addresses:
633E8
633DE
549F8
549F4
549F6
Did you flash this rom to the car?
Old Nov 17, 2009 | 05:03 PM
  #210
yes
