The DTC Disable thread (P1235, P1241, P1238, etc)
I copied the tephra code from page one for the USDM 08 rom into the xml file for the 2010 USDM. I then inputed your addresses for the disable codes and got the correct numbers in the boxes when I openned a 2010 rom in ECUflash. Here are the numbers:
0384
03e8
0026
0028
0028
So the addresses you provided seem to be correct. All I have to do now is change the box numbers to FFFF across the board and test them on a 2010 car.
I tuned a 2010 Evo X this Sunday and I was hesitant to use the disable codes due to FTY's experience though I believe that his expereince is operator error. I ended up adjusting the flow/torque tables instead.
Did anyone test the disable codes on a 2010 Evo X to make sure that they worked?
i did the same thing bryan.
then opened a generic X rom, exit programming and voila.. i stopped sweating!
cb
no doubt it will work i just accidently left in a line of code that shouldnt have been there with the wrong address. it should be ok for you guys. when my ecu gets back from colby i'll try it again lol
Just checking in to see if anything on P0140 or P0139 has popped up! Would love to get that light off my dash...
Since I put my winters (TPMS sensors included), the only light left is the CEL from running my WB O2 sensor through the ADC.
SiC,
0384
03e8
0026
0028
0028
0384
03e8
0026
0028
0028
