The DTC Disable thread (P1235, P1241, P1238, etc)
Old Nov 12, 2009 | 07:07 AM
  #181
evo_q8's Avatar
thats what I did, the boost is now down but i dont want it that way! want the DTC's outta the picture... anyways, im waiting so once hez done, im shooting him a donation he very well deserves it!
Old Nov 12, 2009 | 01:51 PM
  #182
SiC's Avatar
SiC
Since Tephra is a busy guy, I'll add my 2 cents here.
This is from top to bottom, just enter these addresses:
631ea
631e0
549c0
549bc
549be
I haven't tested these but I'm sure they will be fine, just make sure they are the correct numbers in the xml before editing.
Old Nov 12, 2009 | 05:20 PM
  #183
GST Motorsports's Avatar
631ea
631e0
549c0
549bc
549be
Those are the same as 53040010
And they look to be the incorrect addresses for 2010 USDM ROM ID 55570005
EDIT: Nevermind, thought you where talking about USDM 2010. Carry on... nothing to see here...
Old Nov 12, 2009 | 07:10 PM
  #184
SiC's Avatar
SiC
If it uses the same pattern as the 2008 & 2009, then it should be this for the 2010:
633E8
633DE
549F8
549F4
549F6
Again, I don't have a 2010 to test it on so don't beat me up if your ECU blows up
Old Nov 16, 2009 | 01:39 AM
  #185
evo_q8's Avatar
631ea
631e0
549c0
549bc
549be
I will test these today and get back to you! Thanks SiC!
Old Nov 16, 2009 | 12:19 PM
  #186
FTY Motorsports's Avatar
i got the 2010 ecu i can test it on i'll test it in a bit and get back to you
Old Nov 16, 2009 | 12:24 PM
  #187
evo_q8's Avatar
631ea
631e0
549c0
549bc
549be
WORKS LIKE A CHARM! Whoa!
Old Nov 16, 2009 | 02:40 PM
  #188
well i tried it on the 2010 and now im locked out of the ecu i cant flash it or pull the map out nothing. car wont start just like bleh. wat should i do lol
Old Nov 16, 2009 | 02:41 PM
  #189
633E8
633DE
549F8
549F4
549F6
little help here sic or tephra
Old Nov 16, 2009 | 02:54 PM
  #190
tephra's Avatar
^ what were the "before" values ?
Old Nov 16, 2009 | 03:01 PM
  #191
You need to make sure the before #'s are the same as what is post for your rom.
Be careful of blindly making ecu changes on the Evo 10, as you now know what can happen.
The before #'s should be:
0384
03E8
0026
0028
0028
F99F
for these addresses you where trying to change:
631ea
631e0
549c0
549bc
549be
You didn't put those address's into the actual ecuflash table input did you?
Old Nov 16, 2009 | 06:29 PM
  #192
i have to bring up my laptop to see what the values were that were in there before but i put the addresses in and pulled up the table and changed them like it said in the first post and now im kinda stuck i can't flash anything in to the ecu or anything kinda worried right now lol. thats y i usually let others be test dummies for this stuff i thought i would try to help out now im screwed lol
Old Nov 16, 2009 | 06:38 PM
  #193
i used these addresses
633E8
633DE
549F8
549F4
549F6
Old Nov 16, 2009 | 07:01 PM
  #194
633E8
633DE
549F8
549F4
549F6
You put that in the XML or the actual ecuflash input boxes?
Did it show these in the input boxes before:
0384
03E8
0026
0028
0028
Old Nov 16, 2009 | 07:23 PM
  #195
tephra's Avatar
You will need to remove the ECU from the car - and do a bench flash...
there is a thread floating around that I posted some instructions in...
