The DTC Disable thread (P1235, P1241, P1238, etc)
Old Sep 6, 2009 | 07:48 PM
  #76
PR_Mivec's Avatar
will try to emulate them during the week
thx Tephra!
Old Sep 6, 2009 | 08:07 PM
  #77
tephra's Avatar
I like your sig - well everything except the last bit
Old Sep 6, 2009 | 08:13 PM
  #78
HB Speed's Avatar
Code:
LogID	ET	RPM	PSIG	TimingAdv	KnockSum	Load	MAFV	IPW	STFT	LTFT_i	LTFT_C	LC1	0x8087FE	0x8087F0
1	0	906.25	-5.75	17	0	24.06	1.46	1.89	0	0	0	14.05	0	30428
2	0.09	906.25	-5.89	16	0	23.44	1.52	1.98	-0.39	0	0	14.13	0	30428
3	0.2	843.75	-5.65	23	0	25.63	1.52	2.07	-0.39	0	0	14.36	0	30428
4	0.31	875	-5.5	20	0	25.31	1.49	1.94	-0.2	0	0	14.21	0	30428
5	0.42	937.5	-6.13	15	0	23.75	1.49	1.97	-0.2	0	0	14.28	0	30428
6	0.52	937.5	-6.08	13	0	24.38	1.53	2.03	0	0	0	14.55	0	30428
7	0.62	875	-5.6	19	0	25.94	1.47	2.06	0	0	0	14.57	0	30428
8	0.73	906.25	-5.6	17	0	25.31	1.41	1.97	0.2	0	0	14.61	0	30428
9	0.83	937.5	-5.84	13	0	25.31	1.61	2.14	0.2	0	0	14.64	0	30428
10	0.94	906.25	-5.46	17	0	28.13	1.6	2.41	0.39	0	0	14.65	0	30428
11	1.12	1000	-5.31	13	0	29.06	1.6	2.17	0.39	0	0	14.56	0	30428
12	1.25	1000	-5.5	13	0	28.44	1.57	2.17	0.59	0	0	14.56	0	30428
13	1.36	1031.25	-5.55	13	0	28.44	1.61	2.26	0.59	0	0	14.61	0	30428
14	1.47	1000	-5.5	13	0	28.75	1.58	2.29	0.78	0	0	14.53	0	30428
15	1.58	968.75	-5.36	13	0	29.06	1.6	2.29	0.78	0	0	14.63	0	30428
Old Sep 6, 2009 | 08:33 PM
  #79
PR_Mivec's Avatar
heheh is a quote from the late George Carlin
Old Sep 7, 2009 | 04:17 AM
  #80
tephra's Avatar
legend
Old Sep 8, 2009 | 07:15 AM
  #81
drewgray's Avatar
Hi Guys,
Can the people getting P0140 OR P0138 for the rear02:
1) check that your ECU OPTIONS 2 points to 0x50082
2) Post up the HEX of 0x50082
3) Log 0x8087FE (2byte)
4) Log 0x8087F0 (2byte)
Post the results
I have looked at the code and can't see anything obvious as to why 526800XX differs from 530400XX in this regard.
Thanks!
D.
1) Yep, check.
2) 0x76
3) constant '0'
4) constant '48703'
Old Sep 8, 2009 | 07:17 AM
  #82
tephra's Avatar
1) good
2) need both bytes (sorry)
3) good
4) what ROMID you running?
thanks
Old Sep 8, 2009 | 08:48 AM
  #83
drewgray's Avatar
1) good
3) good
thanks
2) 0x76DC
4) 52680018
Old Sep 8, 2009 | 03:23 PM
  #84
jason4656's Avatar
Tephra as ur the man that can , is there any chance you can give the mods to the xml for 52370024 ??????
thx
Old Sep 8, 2009 | 04:08 PM
  #85
tephra's Avatar
email me the ROM and I will take a look
myforumname @ gmail.com
Old Sep 9, 2009 | 09:49 PM
  #86
PR_Mivec's Avatar
ill need this for:
54060007 (2009gsr)
54070007 (2009mr)
Old Sep 10, 2009 | 10:10 PM
  #87
LIGHTSPD's Avatar
Had a little time on my hands why should we make Tephra do all the work
09 MR 54070007
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="63210" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="63206" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549D4" type="1D" scaling="Hex16"/>
<table name="DTC P1233 Disable 0x0028 -> 0xFFFF" category="Misc" address="549D0" type="1D" scaling="Hex16"/>
<table name="DTC P1234 Disable 0x0028 -> 0xFFFF" category="Misc" address="549D2" type="1D" scaling="Hex16"/>
<table name="DTC P0247 Disable 0xF9DF -> 0xF1DF" category="Misc" address="937B2" type="1D" scaling="Hex16"/>
Cheers Cam
Old Sep 10, 2009 | 10:35 PM
  #88
LIGHTSPD's Avatar
Originally Posted by PR_Mivec
ill need this for:
54060007 (2009gsr)
54070007 (2009mr)
If you want to send me the rom for 54060007 I will be happy to help you out.
PM me for an email
Cheers C
Old Sep 11, 2009 | 12:17 AM
  #89
PR_Mivec's Avatar
pm sent thx!
Old Sep 16, 2009 | 05:45 AM
  #90
Hiboost's Avatar
Just wanted to report that these disable codes worked like a champ for me. I was getting sick of the stationary limiter triggering the airflow or torque codes so I lowered my limits to ~225 at 6000 and beyond and then entered the disable codes.
