No activity from fuel trims
Old Sep 14, 2009 | 07:03 PM
speedypollard's Avatar
There's only a couple possibilities why this is happening. Either the o2 sensor isn't wired up correctly (I have a swapped car) or I accidentely disabled the front o2 through the perephery files. Here is a log and my tune and maybe someone can find a hint.
Here's my log from MitsuLogger:
http://www.4shared.com/file/13269295...11-135330.html
Here's my ECUFlash tune:
http://www.4shared.com/file/13269318...chertest1.html
Old Sep 14, 2009 | 07:24 PM
hediki12's Avatar
https://www.evolutionm.net/forums/4485725-post195.html
Old Sep 14, 2009 | 07:29 PM
hediki12's Avatar
try that copy that into ur evoscan xml
Old Sep 14, 2009 | 08:10 PM
Mine were the exact same other than the log reference name which I don't think matters. On the next page of that thread is the syntax for evoscan and mine were the same as well other than the eval function for "ltft_low"
Old Sep 14, 2009 | 09:22 PM
hediki12's Avatar
sorry wrong xml its suppose to be this
<DataListItem DataLog="Y" Color="" Display="LT Fuel Trim Low" LogReference="LTFT_Low" RequestID="0C" Eval="0.1953125*x-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-13" GaugeMax="13" ChartMin="-13" ChartMax="13" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="LT Fuel Trim Mid" LogReference="LTFT_Mid" RequestID="0D" Eval="0.1953125*x-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-13" GaugeMax="13" ChartMin="-13" ChartMax="13" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
<DataListItem DataLog="Y" Color="" Display="ST Fuel Trim" LogReference="STFT" RequestID="0F" Eval="0.1953125*x-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-25" GaugeMax="25" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
that made my fuel trims log up past that into the evoscan xml file and open evoscan and you will see them uncheck the originals and select those there is no ltft for high tho. also i can look at your log right now if your if your o2 sensor bounces around you should be getting a fuel trim i had the same prob this fixed it for me.
Old Sep 14, 2009 | 09:23 PM
hediki12's Avatar
off topic-
also whats a 2000 eclipse gsx? lol. i thought 99 was the last yr.
Old Sep 14, 2009 | 09:29 PM
Resi's Avatar
did you disable closed loop? if so, that would be the cause, must enable closed loop and the trims will start doing their thing!
Old Sep 14, 2009 | 09:31 PM
Originally Posted by hediki12
off topic-
It's my own little creation...
http://www.youtube.com/profile?user=.../4/uWQHFkhATf8
Old Sep 14, 2009 | 09:38 PM
I don't think I did. Sorry I'm like 3 days new to learning this stuff..
Old Sep 14, 2009 | 10:31 PM
hediki12's Avatar
o2 senso seems ok i guess... umm once it warms up.. try the xml i gave you and let me know....
Old Sep 14, 2009 | 10:34 PM
4WS Tuning's Avatar
Nice Vids Boston!
Old Sep 15, 2009 | 06:37 AM
jrohner's Avatar
You don't happen to have a low temp thermostat do you? What's your water temp get up to?
Old Sep 15, 2009 | 09:37 AM
No I don't think so. At idle the coolant temp cycles around 190.
