Adding load columns and RPM rows to maps
Old Oct 9, 2009 | 06:02 PM
  #271
Jack_of_Trades's Avatar
Originally Posted by phenem
2. mrfred psi based boost implemented (just edit Tephra's gear dependant map)
Why don'y you make a section with the tables that need to be edited to switch between load based/PSI based conversion, then have one section with the tables scaled for load and another section scaled for PSI? That's what I do so I don't need to rescale anything in the tables, just edit the settings so the ECU reads the MAP instead of load.
Old Oct 9, 2009 | 06:16 PM
  #272
phenem's Avatar
Each user can choose how they want to do that, just change the scaling to load or psi based on how you like to "see" it.
Is that what you mean?
Old Oct 9, 2009 | 06:38 PM
  #273
Not exactly, I will post up an example soon
Old Oct 9, 2009 | 07:40 PM
  #274
Evo_Jay's Avatar
Originally Posted by logic
Why?
Not needed. 9653 works great you just need to take the time and get it configured correctly.
In the end I am making three different ROM's from tephra's v7 final distribution to make it easy for people so it's just plug and chug
My answers to these ^^^ are below...
Originally Posted by MR Turco
This is what i dont get, why do we need to force a rom on that takes time to configure and doesn't just work? Why not just have 1 more rom that we all know works without issue? I fully support the idea of keeping 94170015 in the patch stream.
Originally Posted by Appauldd
Although I don't care to have bigger tables.....I too believe that having the 94170015 ROM supported would be very beneficial.
Not only does this rom work without making it work, but DSM guys can easily run it as well.
Old Oct 9, 2009 | 07:42 PM
  #275
Evo_Jay's Avatar
Originally Posted by jack_of_trades
if someone takes the time to make 96530706 work as smoothly as 94170015 does now, i'm all for it. i certainly don't have the patience or time to have to f*ck with every 96530706 rom to make the end user happy with his tune. As much as everyone who obviously doesnt own an evo8 would like to assume, 96530006 has flaws. I understand the concept of less rom's to mod, i just feel the 94170015 is more stable....currently. Personally, i'd love one rom for 8's and one rom for 9's. Unfortunately, the rom everyone chose for the 8's can be sooo difficult to work with at times. The 94170015 rom only had a knock sensor sensativity issue with modded evo's but once we found the knock multiplier tables the issue was no more. Hopefully we can have the same happen for the 9653 rom soon.
probably because people are being forced to, with the elimination of 94170015 with current mods. They are just showing their concern since they will have little choice unfortunately. I always had those issues but never used it because 94170015 was available and extremely stable and reliable.
Originally Posted by appauldd
supposedly money isn't a motivator, but if you were to incorporate 94170015 into the list of fully supported roms, i am quite certain that fundage will readily come available.
Those of us with the first us evos have enjoyed this rom with nearly no issues. The edm rom seems to have issues on usdm cars.
i realize the need to have as few roms as possible to aid in the haste of which they can be supported, but the differences between edm and usdm are too vast to not have seperation.
(goes on knees with hands clasped looking up with puppy dog eyes and pouty lips)
p, p, please make the 94170015 fully supported.
+1
Old Oct 9, 2009 | 07:43 PM
  #276
Evo_Jay's Avatar
Originally Posted by Slo_crx1
Up to this point I hadn't seen any real definitions on it, so I pretty much ASSumed that it wasn't incorporated into the rom, similar to the 0008's.
I'll play around more on my car with the 96530006 rom and see how it reacts. I just have more familiarity with the 0015 rom is all.
This...
Originally Posted by 03whitegsr
I would imagine lean spool is on all of the ROMs (least all USDM ones AFAIK). If or not it's defined in the XML is the issue that I was talking about above.
Old Oct 9, 2009 | 07:55 PM
  #277
Evo_Jay's Avatar
As I dont use alt maps or ECU boost control, Im still running Tephra original NLTS+cel on knock+valet ROM (96420008).
I really would like to use the new bigger maps feature though, but dont wanna deal with 9653. I dont even wanna configure it to work. I would like a USDM ROM as I just like a more simple and stable approach.
*Also a lil side not, it you did a 9417 ROW, we could use it in place of the 9653 AND the 9694, and completely ELIMINATE the throttle hang problem for all EVO VIIIs
Old Oct 9, 2009 | 08:00 PM
  #278
Evo_Jay's Avatar
I guarentee the issues most of you are seeing with wrong data in the wrong place is XML definition issues.
When tephra posts the v7 both of us agreed that I will get the second post for the USDM conversion 9653 ROM. I have created three versions which include all XML's and information needed. They are noted below:
Download 1:
1. Bone stock ROM with USDM immob. fixed
Download 2:
1. Immob. fixed to work on USDM cars
3. OBD II Inspection ready for EVAP and EGR
4. Disabled EGR, EVAP, and Idle Tests
5. Disabled P0300 code
6. Disabled lean spool
7. Disabled boost cut
8. Disabled boost delay cut
9. Fixed throttle hang under partial throttle (this fix worked for my car, might not on others)
Downloads 3:
1. Everything that Download 2 has with Speed Density Implemented
That is what I will be posting once Tephra gives me the OK to post up!
That should make most issues and problems go away once everyone is running the same ROM and have all the same XML's.
LOL. I made all my post above, but this may work, if 9653 was already configured for USDM EVOs and available for DL.
Either way. I like your idea, great idea to make it easy for USDM cars to use 9653.
**I would maybe not do #9 for download two. Since we havent found the exact fix. just a suggestion
Old Oct 9, 2009 | 09:20 PM
  #279
lol, it was funny watching your posts unfold like a story haha.
Old Oct 10, 2009 | 05:11 AM
  #280
phenem's Avatar
You are correct #9 is pending, I am still testing as are others. If I do find a way to fix it on my car I will give the instructions and leave it up to the user to implement if they choose most likely.
JofT is going to help me implement a better way to incorporate mrfred's psi or load based boost control.
JofT can you email me when you get a chance?
phenem at gmail dot com
Old Oct 10, 2009 | 10:48 AM
  #281
Here is a snapshot of how I have my 96530006 XML setup for MrFred's PSI based boost. I made a copy of those tables and have them scaled for load and give them their own category. The load tables are technically already loaded in the evo9base XML but I prefer to simplify the organization by making my own section that easier to read/follow. This way when I open someone else's ROM, I can see whether they are running PSI based boost control or LOAD based boost control quite easily without editing all of my scaling if I convert them.
Old Oct 10, 2009 | 10:52 AM
  #282
Appauldd's Avatar
+1......That is awesome. Please tell me that is in the new V7.
Old Oct 10, 2009 | 11:14 AM
  #283
Hopefully they can do something with the concept. I think it needs to be updated for the new Gear Dependent boost control tables though.
Old Oct 10, 2009 | 11:46 AM
  #284
fixem2's Avatar
I like that layout!
Old Oct 10, 2009 | 12:50 PM
  #285
mrfred's Avatar
Nice!
