Adding load columns and RPM rows to maps
Old Oct 6, 2009 | 05:49 PM
  #226
steadly2004's Avatar
Originally Posted by tephra
V7 includes BIGMAP...
Thought I might as well sneak it in
Sorry testers!
So you no longer work on the 94170015
Just with the 96530706?
I can't wait for this V7 to come out!
I originally had the 94170008, and changed to 94170015, so I will need to change to 96530706 now? When the V7 comes out to get BIGMAP?
Old Oct 6, 2009 | 06:06 PM
  #227
tephra's Avatar
correct.
unless there is a really compelling reason todo a 94170015 I will try to avoid it
Old Oct 6, 2009 | 09:25 PM
  #228
denver's Avatar
correct.
awwww...... define a compelling reason....
I have been trying to avoid changing roms again... but with all the cool features in V7 i guess Ill give in and change
Old Oct 6, 2009 | 09:30 PM
  #229
tephra's Avatar
a compelling reason would be you have to make significant changes to get 96530006 to run on your 94170015 car...
at the moment the only thing thats been raised is the revhang stuff, which can be fixed using tables.
Old Oct 7, 2009 | 12:19 AM
  #230
R/TErnie's Avatar
So,
for the 88950015 ROM which I have... who is working on adding more load/rpm colums/rows?
Sorry if my question is dumb in any way.
Old Oct 7, 2009 | 01:38 AM
  #231
codgi's Avatar
Originally Posted by logic
Ugh, I should never post when I'm tired, I screw up things like "word definitions" and "sentence structure". The table lookup itself is fixed-cost, ie. O(1), but each axis lookup is a search over the width or height of the table, so a maximum of O(n), but no worse. You had it right.
Hey I was tired too so.... . With what Ceddy says seems its moot
Old Oct 7, 2009 | 01:48 AM
  #232
tephra's Avatar
Ernie - it will be integrated into V7
Old Oct 7, 2009 | 06:10 AM
  #233
MR Turco's Avatar
so it is ok to change the 11k value at the end of the RPM stack right? I had posted a while back and it seemed fine but i find it odd it is like that. Not sure if there is a specific reason.
Old Oct 7, 2009 | 06:17 AM
  #234
Jack_of_Trades's Avatar
I see no reason why it couldn't be changed. Once the RPM exceeds the last known RPM value on the list, it just holds the last known settings in the map, which would be the last row of data.
Old Oct 7, 2009 | 07:27 AM
  #235
MR Turco's Avatar
thats what i figured, it is just odd they jump from 7500 to 11k.
Old Oct 7, 2009 | 02:13 PM
  #236
tephra's Avatar
its so it interpolates down - just incase you change the revlimitter is guess...
dunno...
Old Oct 7, 2009 | 02:16 PM
  #237
cossie1's Avatar
I always thought it was there as a backup, just incase you "miss shift" and end up over revving the engine.
Old Oct 7, 2009 | 02:17 PM
  #238
03whitegsr's Avatar
The ECU doesn't cut spark above the rev limiter. It's likely mapped out that high just so it has a known value should the motor be beyond the rev limit. Otherwise, it would have to extrapolate, which is never a good thing. There is no need for that on fuel since it cuts fuel above the limiter.
That would be my guess.
Old Oct 7, 2009 | 03:19 PM
  #239
But it HAS a known value, the last row of data that it passed. It will use that row of data until it's told to do otherwise, it's modal.
Old Oct 7, 2009 | 03:40 PM
  #240
03whitegsr's Avatar
Does it just use the last value or does it use the last two and extrapolate?
