Adding load columns and RPM rows to maps
Old Oct 5, 2009 | 12:00 PM
  #196
knochgoon24's Avatar
Originally Posted by mrfred
...Fuel on the other hand is a bugger because what you put into the map is never what you get in real life, and I constantly have issues with the fuel doing funny things inside of an increment. This is especially true at low to mid rpms. Here, I think it might be nice to perhaps go to load increments of 15 or maybe 10. Out past about 5500 rpm though, fuel never seems to do anything unexpected, and I think we could get away with a load increment of 30 for load cells from 5500 rpm and onward.
Any chance that expanding the MAF scaling table (for more resolution) might help? I know I'm having problems with dialing the 2g MAF in on my 2g DSM. I'm getting repeatable results, but I'm running rich/lean between given points (Hz values). Each point is dialed in, but points in between aren't.
My biggest problem is between 302 and 403 Hz. Both of those are spot on, yet I still run 1.2AFR lean at worst in between. A 350Hz adjustment would help, which I should be able to add by deleting the 25Hz cell (same as my 19Hz) and adding the 350 in. I think the MAF Compensation/Smoothing is the only other table affected.
But more resolution in general would make this really nice. For some reason, there are lots of people with ups and downs in their MAF scalings. I know I do.
Old Oct 5, 2009 | 12:09 PM
  #197
Jack_of_Trades's Avatar
Are you running the stock intake pipe?
Old Oct 5, 2009 | 12:14 PM
  #198
MR Turco's Avatar
Originally Posted by phenem
The way to adjust it is let the car completly warm up. In EVOScan set the car into BISS mode (can't remember what you actually click, anyone else know?) once that is set you adjust it to within 800 RPM + or - 50 RPM. Then you deactivate the mode and you are good to go. What it does it put the car into a mode where the ICSV stepper is not trying to adjust anything that way you can set the screw correctly.
What if the car is already idling fine?
Old Oct 5, 2009 | 12:25 PM
  #199
logic's Avatar
The car will generally idle great (until the ISC starts to die), but you can still have badly mis-adjusted BISS; the ECU is just compensating for the problem.
Old Oct 5, 2009 | 12:56 PM
  #200
jid2's Avatar
Holy ***** - I love you guys, in a very non-gay way... as someone else pointed out.
Do need for some -94170015. I like the 25X30 size.
Old Oct 5, 2009 | 12:57 PM
  #201
If you get a CEL for the ISCV being out of its adjustable range, then the BISS/ISCV tables need work. You can get it dialed in just fine at any idle RPM if you take the time with it. I would re-enable the periphary and keep working at it.
Old Oct 5, 2009 | 01:17 PM
  #202
rolly1818's Avatar
Registered User
dave,
will this be available for 88570008?
would be great to have this along with V7!!!
Old Oct 5, 2009 | 01:33 PM
  #203
No. I have an eBay hard pipe. I think my numbers are lower because I only have a 3" filter. I know that's my biggest restriction in my whole engine right now.
I'm just read about how the MAF smoothing works. I didn't copy those over from the 2g rom. I have a few things to try.
I just figured I'd mention expanding the MAF Scaling table just a bit while the talk of expanding other tables was ongoing.
I'm not sure if my problems are unique to those of us who are trying to run the Evo Ecu in our DSMs, or if you guys are having similar problems too.
Old Oct 5, 2009 | 03:04 PM
  #204
tephra's Avatar
The revhang stuff should be able to be solved by fiddling with the right hand column of the ISC Stepper table, it should NOT affect cold start (since the right hand column is 41C+ or something)
Old Oct 5, 2009 | 03:22 PM
  #205
phenem's Avatar
I have tried everything to get this to work on 9653 but it doesn't. No matter how many times I adjust the BISS screw it throws the code. I think it is a hardware difference between USDM and EDM. If I put the 9417 ROM in and set the BISS I don't see the SES come up. Only on the 9653 does it present this issue. The only way I found a way for it to work is set the BISS screw and disable the periphery bit and it works perfect.
Old Oct 5, 2009 | 03:34 PM
  #206
mfr122887's Avatar
These are the stepper tables and decel fuel cut tables from 94170015 on the left and 96530706 on the right. They are extremely different, I am going to set them equal and go for a drive. Has anyone done this?
edit: just realized that you cant see the numbers but just by the colors they are drastically different. I'll get a better screenshot up in a little while.
Old Oct 5, 2009 | 03:39 PM
  #207
l2r99gst's Avatar
There are a ton more ISCV tables that mrfred found and I did my best to find them for 96530006. I think a couple of them are RPM based and may be worth a shot to play with. Let me find the thread and link it here.
Here you go:
iscv-control-system-disassembly
Eric
Old Oct 5, 2009 | 03:53 PM
  #208
Evo_Jay's Avatar
I guess, but I don't consider it an issue, just an inconvenience I hardly notice on my car when I drive. Maybe we are talking about something different cause my car isn't that bad.
My issue: When I leave of the gas my car goes rich (around 10-11-12 AFR) stays there for about 5 seconds then comes back down. Car sometimes bucks a little but not that bad at all. Is this what everyone else is experiencing?
It's def. in the fuel cut decel table just have to find out how to fix it. You are right though it only happens when switching to 9653 cause if I switch back to 9417 it goes away.
I am going to compare those maps from 9417 to 9653 and see if I come up with anything.
OFF TOPIC
I already compared the "Decel fuel cut delay" tables" in 96940011 and 88950015 (them both having throttle hang) with the ones in 9642008 and 94170015 (they dont have throttle hang). The values are different, but when I put the non-throttle hang values in a throttle hang ROM, it doesnt take away the throttle hang.
*i tired this on a car Im remote tuning, so i didnt get to actually drive the car and test it for myself, but the guy said the hanging remained.
  #209
l2r99gst's Avatar
Also, there are decel fuel cut delay tables, which may do what you are looking for. I don't have them defined in my XML, but I'm sure they are on the forum...if not, I will find them for 96530006.
Old Oct 5, 2009 | 04:04 PM
  #210
Evo_Jay's Avatar
I dont think that that table is deffined correctly or something.
In the begining of ECUflash, when I had my IX, I did a lot of messing with the ISC stepper table. I was able to find a good balance of gettin rid of the throttle hang and still having cold start, but I dont think that is the correct way to get rid of the throttle hang. Like I said above, I think it has more to do with the "Decel fuel cut delay" tables.
Also when i tried the ISC Stepper setting that I used in my car to get rid of throttle hang on another car, they experienced poor cold start and said throttle hang remained.
