Adding load columns and RPM rows to maps
Old Oct 4, 2009 | 05:32 PM
  #151
tephra's Avatar
ok guys,
I really want to finalise the map size (and therefore ROM location)
Can I please get a vote on:
25 RPM and 29 Load (what I have posted thus far)
25 RPM and 30 Load (for nice round numbers)
30 RPM and 30 Load (not sure if we need so many RPM's)
* some other size (post up what you think)
Old Oct 4, 2009 | 05:52 PM
  #152
EvoDan2004's Avatar
IMO if its an option 30x30 is my vote. the more the better. if it can be done you miles well go all out that way it will benefit every single person.
my new setup i would really like 250rpm increments and 10 to 20 scale load increments as i will be up to the 460 500 area. so i vote for the more the better.
30x30 haha.
Old Oct 4, 2009 | 05:55 PM
  #153
JohnBradley's Avatar
25x29 fits my desires, but 25x30 will work just as easy. Might as well go a little bigger if its no extra trouble.
  #154
Jack_of_Trades's Avatar
Originally Posted by tephra
ok guys,
The more the better. If you can fit 30x30,then by all means...do it up!
God, going from 19x20 to 30x30 is nuts. That's like 235% bigger! If I look at the stock maps now, I just think "God its so small!"
Old Oct 4, 2009 | 06:06 PM
  #155
Fast_Freddie's Avatar
Veteran: Navy
I am up for anything... but 25x30 sounds good to me, nust for the round numbers!
Old Oct 4, 2009 | 06:15 PM
  #156
phenem's Avatar
25 x 30 is perfect for me!
Old Oct 4, 2009 | 06:19 PM
  #157
ziad's Avatar
i think u might have problems with people wanting to run live map if going that high (30x30) and yes there arent too many of us.
Old Oct 4, 2009 | 06:21 PM
  #158
tephra's Avatar
yeh I have taken a quick look at livemapping, realistically we have 2k of memory to work with, so 30x30 maps are 900+ bytes each, so basically the fuel+timing will take up 90% of the livemap RAM space...
I can do 30x30 - its not too hard, I would prefer to get it right first time around
Old Oct 4, 2009 | 06:25 PM
  #159
TTP Engineering's Avatar
Forget the livemapping. You need a C++ certification to even understand that stuff anyhow.
Old Oct 4, 2009 | 06:27 PM
  #160
phenem's Avatar
https://www.evolutionm.net/forums/ec...able-size.html
Old Oct 4, 2009 | 06:37 PM
  #161
ziad's Avatar
25x30 ftw.... no its like a Japanese electronics gizmo... looks cool but no one knows what the buttons mean
anyway i though ppl wanted a standalone ecu functionality, so live mapping is it
Old Oct 4, 2009 | 06:39 PM
  #162
logic's Avatar
Interestingly, that's the kind of thing people were saying about working with EcuFlash as a general tuning tool just a few years ago.
Old Oct 4, 2009 | 06:41 PM
  #163
phenem's Avatar
In case anyone didn't see
VOTE HERE!
Old Oct 4, 2009 | 06:50 PM
  #164
mrfred's Avatar
tephra or logic, have either of you guys given any consideration to the additional processor cycles required to do a lookup using the larger maps?
Old Oct 4, 2009 | 07:05 PM
  #165
tephra's Avatar
yes.
there are 2 things here:
1) the extra axis lookup's I have had to implement into the IgnitionLookup routine
2) the extra cycles required for having bigger axis's.
In both cases I think the overall hit to performance will be marginal, given there is SOOO much code in the ECU this little change seems fairly harmless.
You thoughts?
