Adding load columns and RPM rows to maps
Old Oct 1, 2009 | 10:02 AM
  #46
JohnBradley's Avatar
MIVEC shouldnt need to be rescaled as well Dave. I think its pretty easy to curve and at high load we'd be dropping the value anyway.
Old Oct 1, 2009 | 10:03 AM
  #47
03whitegsr's Avatar
Cobb may only be doubling a couple of the maps and not the entire ROM.
One or two of the VIII ROMs are actually so full that even the work Tephra has done won't fit on them.
Old Oct 1, 2009 | 10:41 AM
  #48
On the IX I'd completely delete the high octane 2,3 low octane 2,3 stuff from the ROM if it wasnt already. I cant remember if the lookup was just changed or it was removed The 9694xxxx is the one that ran out of room, yes?
Old Oct 1, 2009 | 10:45 AM
  #49
I did some brief testing, if possible dimensions of 27x26 will be more than adequate.
Old Oct 1, 2009 | 11:45 AM
  #50
R/TErnie's Avatar
I'm down for whatever we can get. The more the better. Fuel Maps, Timing Maps... and I'd like more RPM rows and Load columns.
I have the 88950015 ROM.
Old Oct 1, 2009 | 11:48 AM
  #51
laramie_05MR's Avatar
Originally Posted by tephra
ok I will do it... I will let u guys decide if you want to donate
do we need MIVEC done as well?
Love you man in the purest heterosexual way possible This is freaking awesome.
Aaron is correct about the only rom that has ran out of room. 96940011 was my orig. rom.
Old Oct 1, 2009 | 03:59 PM
  #52
tephra's Avatar
yeah atm im working on 25rpm by 29load.
TephraMods already disables the use of 2 and 3 ignition maps.
unfortunatley the low oct maps will also need to grow
Old Oct 1, 2009 | 04:10 PM
  #53
That will work better based on what I am looking at right now on my lappy. Especially for SD cars that need resolution vs Kpa. The additional 5 rpm slots will allow good control all the way around and should run out to 10k pretty easy.
Old Oct 1, 2009 | 04:27 PM
  #54
tephra's Avatar
I will post up a pic when I get to work...
Really the hardest bit in all this is taking the existing maps and smoothing them across the new rpm/load points..
I am tempted to leave the maps blank and let u guys do that
Old Oct 1, 2009 | 04:32 PM
  #55
nothere's Avatar
couldn't the low octane map be destroyed? I mean with all the other fault fallbacks if you can't keep your foot out of it and end up in low octane map you deserve to be punished.
Old Oct 1, 2009 | 05:02 PM
  #56
MR Turco's Avatar
destroying the all the low octane maps is a terrible idea. it is another safety net that should be utilized.
Tephra, sending donation now.
Old Oct 1, 2009 | 06:27 PM
  #57
logic's Avatar
Absolutely agreed on the notion of completely removing the concept of "octane" from the ECU; it's an important component of a street car configuration, as you'll find out the first time you get a bad tank of gas. (I'd argue it's about as silly as getting rid of fuel trims, but there's some full-time open-loop guys who'd take issue with me. )
But I have to wonder if we couldn't do something algorithmic rather than entire dedicated maps for the low-octane configuration. I'm thinking something like a transformation of the octane calculation into an AFR and timing modifier, that decreases timing/increases AFR up to some adjustment maximum (ie. when applying the adjustment value, never exceed X AFR, never go lower than Y degrees of timing). Think an "octane" trim, much like fuel trims, that is applied to the high-octane values in place of referencing a low-octane map. As the octane value reduces, the adjustment becomes more dramatic (perhaps in a configurable, linear, manner)?
The main advantage I could see here would be that it takes the low-octane tuning out of the picture, since most people don't seem to ever touch those maps (and in some cases, they probably should; I've seen rescaled timing and fuel axes, with stock low-octane map contents, either through laziness or incompetence).
Anyway, just thinking out loud.
Old Oct 1, 2009 | 06:30 PM
  #58
0xDEAD's Avatar
For tephra donations:
http://dsm-ezine.com/tephra_donation.html
Old Oct 1, 2009 | 06:52 PM
  #59
TTP Engineering's Avatar
Yum.
Old Oct 1, 2009 | 07:56 PM
  #60
nothere's Avatar
if every time real knock happened the wastegate told the turbo, you aren't getting any, there couldn't be a better failsafe. or a need for one
