Speed Density Issue
Old Oct 2, 2009 | 01:04 PM
l2r99gst's Avatar
As far as cold starting is concerned, you need a lot more fuel added to the cranking IPW at the 7C mark and below. Temps just started to fall here in Chicago so I have had the chance to start tuning for this. Before I had to try 3-4 times before it would fire. Now, it does on the fist, sometimes second try, although I'm still in the process of fine tuning.
Old Oct 2, 2009 | 07:33 PM
whitey4d's Avatar
Originally Posted by EVO8LTW
My car is running SD and I've experienced the known issue. It's nothing like what you are describing. It's very subtle. It sounds like you have a much bigger problem. Are you sure that the AFRs aren't running super lean when it's running rough?
I agree. I can make the car do it and also stop doing it at will it seems. With my aggressive set up I have way more drivability issue then some slight jumpy AFR at 15% TPS below 2500 rpms when on the stock MAF.
Evo_9xxx
Nov 7, 2020 04:58 AM
need_an_evo
Mar 29, 2016 09:14 AM
need_an_evo
Mar 28, 2016 02:21 PM
slowsrt4:(
Apr 2, 2015 03:40 PM
neonglh
Oct 6, 2010 07:25 AM
