Poor Cold Idle (Yes I searched)
Old Oct 21, 2009 | 11:55 PM
  #121
Fast_Freddie's Avatar
Veteran: Navy
Kick me in the nuts.... I went over my maps again today and for some reason I had the injector scaling set at 636 instead of 650 :facepalm: I was beyond livid when finding this out... so I have to start over on my fuel trims & maf scaling... FFFFFFFFFFFUUUUUUUUUUU!!!!
Old Oct 22, 2009 | 12:01 AM
  #122
Veteran: Navy
Originally Posted by nothere
correct me if I'm wrong, but it looks to me like no matter what your trims are there is a cold idle map of some sort that is overriding and causing your feedback trim to go way rich for a short time.
You are correct in that assumption...at least that is the way that I interpret what I am seeing in evoscan when it transitions from open loop warm-up to closed loop warm up...
Old Oct 22, 2009 | 04:48 AM
  #123
Appauldd's Avatar
Freddie....don't stress it....we all make mistakes. Just look at it as a learning experience. Bet your warm start issue goes away...Hehe.
Old Oct 22, 2009 | 05:25 AM
  #124
Veteran: Navy
^ Lets hope so... Warm starts aren't too bad to begin with...
Old Oct 22, 2009 | 10:38 AM
  #125
Jorge T's Avatar
Paul, this is good news! I'm still pondering if to go directly to v7 or do 94170015 v5.10. Any Throttle hang issues on your 03 with v7?
Originally Posted by Appauldd
Actually there is a table that affects cold idle....see post 98 from Logic. The put the xml into your v7. When you open the table, change the idle area to match your current idle timing. Only change the idle areas (the 5s). Doing this has greatly improved my cold idle.
Today I removed all of my EGR and EVAP junk. Started the car when it was cold....went for a small drive in the neighborhood......PROBLEM SOLVED ! !
I owe it to v7 and Logic for finding the xml that needed adjustment.
Old Oct 22, 2009 | 06:36 PM
  #126
Appauldd's Avatar
You are going to love this......
I removed all of the EGR and EVAP stuff then went in and disabled the peripherys and did the new way of EGR disable and wouldn't you know.....Cold idle issue has returned.
It appears that one of the peripherys is causing my cold start issue. GRRRRR
Oh and it is throttle hanging a bit too.
Old Oct 22, 2009 | 06:57 PM
  #127
Appauldd's Avatar
The following were disabled....
Table
EGR System Enable/Disable....changed from 1 to 0
Periphery FAA bit 11 (Disable EGR . Enable Ign Adv) set to 1
Periphery FAA bit 9 (enable warmup ign retard) set to 0
Periphery FCA bit 15 (P0443, P0446, P0403, P0243, P0090, P2263) set to 0
Periphery FCA bit 14 (P0450, P0451, P0452, P0453 Evap) set to 0
Periphery FCA bit 13 (P0441, P0442 Evap) set to 0
Periphery FCA bit 10 (P1400 MAP sensor) set to 0
Periphery FCA bit 9 (P0401 EGR Test) set to 0
Periphery FEA bit 14 (P0069 MAP vs Baro) set to 0
Upon removal of the EVAP and EGR stuff my car had codes P0505, P0453, and P0403
The codes are, of course gone now because of disableing the bits. Unfortunatly the cold idle issue has risen its head, as has a bit of throttle hang.
I think we need to dive deeper into the periphery bits to ensure that these bits don't affect something else, thus causing adverse conditions.
Old Oct 22, 2009 | 07:41 PM
  #128
Appauldd's Avatar
I made some changes....Will test tomorrow.
Periphery FAA bit 11 (Disable EGR . Enable Ign Adv) set back to stock setting = 0
Periphery FAA bit 9 (enable warmup ign retard) set to back to stock setting = 1
Periphery FEA bit 14 (P0069 MAP vs Baro) set back to stock setting = 1
These don't affect a CEL so, in theory, they can be left alone if the others, as stated above, are disabled.
I did this because I am not certain that these do not affect other idle areas.
More to follow.
Paul
Old Oct 22, 2009 | 09:08 PM
  #129
fixem2's Avatar
I posted in your other thread, but FAA Bit 11 needs to be left alone. The new EGR table mrFred defined does the same but does not effect the other things Bit 11 hits.
Old Oct 22, 2009 | 09:25 PM
  #130
Appauldd's Avatar
That is my plan...See above. I will report the findings tomorrow.
Old Oct 22, 2009 | 09:40 PM
  #131
project_skyline's Avatar
I read through the first 7 pages.
Have you disabled warm up ignition retard? I have CL disabled for startup(like johnbradley mentioned) and have no problems with idling.
Saw that you had, I would leave warm up ignition retard disabled.
Old Oct 23, 2009 | 10:51 AM
  #132
Appauldd's Avatar
Jorge T,
Go ahead and make the switch. You will like the improvements. The car will run EXACTLY like it does on your current rom.
My issues are more of me being **** than anything else. Perfection always comes at a cost....in this case it is my own personal frustration of wanting a 450whp daily driver car that gets 26mpg and can run low 11/high 10s at the track. I guess we can't have it all.
Reguardless, make the switch and tune with v7 since 9417 series roms won't be supported any more.
Paul
Old Oct 23, 2009 | 11:29 AM
  #133
Jorge T's Avatar
Thanks Paul, I'll do v7 then, I have already ordered injectors to go E85.
Have you tried copying the 9417 iidle stepper lookup table over to 9653 v7 to see if the hang goes away?
Old Oct 23, 2009 | 11:53 AM
  #134
Appauldd's Avatar
I have not changed the stepper table....the values in the idle areas are so close, I doubt it would do anything.
I believe one of these 3 creates the issue.
The 2 FAA tables do not need to be changed from stock values if the EGR disable table is used.
As for the FEA bit 14, I have a hunch that the baro adjustment is necessary for good cold drivability.
Old Oct 23, 2009 | 03:46 PM
  #135
Veteran: Navy
Paul... DO NOT change the ISCV tables... leave them alone... I tried that today and the car was retarded. I have an 05 too, which is closer to the 0006 rom in many ways.
