TephraMod V7
Old Mar 16, 2017 | 07:41 PM
  #3421
TurkoTec's Avatar
Hello
I just donated, I would like the evo 7
Originally Posted by tephra
sorted..
but saturday isn't really last week
Old Mar 16, 2017 | 08:12 PM
  #3422
ant_turbo's Avatar
ok the rom that ur trying to DL from ur evo.. was the car tuned??
Originally Posted by TurkoTec
Is is this the tephra v7?
Old Mar 16, 2017 | 08:40 PM
  #3423
TurkoTec's Avatar
Hey
I want to delete my maf
Old Apr 15, 2017 | 02:14 PM
  #3424
3kg's Avatar
3kg
90556701 XML wanted
... I posted this in a thread "90556701 v7" as well...
Hello, I would like to convert to SD and this (90556701) prob is the best rom, now using tephra V7 90550701 or 90552701.
Where do I get the 90556701.xml?
Is it donate David?
Or is it "somewhere"?
Thanks for your help.
Cheers
Old Apr 20, 2017 | 09:50 AM
  #3425
Dragracer187's Avatar
Is there V7 for 99860002?
Old May 8, 2017 | 01:06 PM
  #3426
3kg's Avatar
3kg
^up, still needing 90556701.
(Have no problems donating - just need to know it's properly available. In the past, this was much easier. I guess has to do with retirement)
Old May 8, 2017 | 06:01 PM
  #3427
ecktt's Avatar
Anyone have the most complete XML for the 90550701.
The file attached is the one I have in addition to the one supplied with the rom.
File Type: xml
Old May 24, 2017 | 07:02 PM
  #3428
CLASHY's Avatar
05 evo 8 need help
Hi there I'm very new to this evo things .
so I have this 05 evo 8 looking to get tune or start tune I've read many formrum and I still confused of how the mods work so is there anyone can help me out on how the mod the Rom and use it the Data log and such.
I do my 2.0 openport
My English is not the good
Thanks
Old May 25, 2017 | 05:57 AM
  #3429
ronaldo9's Avatar
I suggest you watch all 16 videos and read the link below.
https://www.evolutionm.net/forums/ec...-tune-evo.html
Thanks
Old Jun 4, 2017 | 07:04 PM
  #3430
1_blue_evo's Avatar
Hi tephra. I just donated. Could please send me a jdm evo 7 rom with Speed Density. Thanks in advance.
Old Sep 4, 2017 | 09:19 PM
  #3431
Jayge91's Avatar
Huge thanks to everyone that contributed to this, it's absolutely amazing!
I'm on the 96531706 rom, i'm just mindblown at how quick it is to get running, and it idles and drives incredibly smooth, even on out-of-the-box settings.
Had to do the minimum ipw mod to get reasonable pump-gas AFR's on ID2000's (and i think it'd be a great thing to add to the xml's standard), but it just WORKS!
Thank you!!
Old Sep 6, 2017 | 12:39 AM
  #3432
mines5's Avatar
"96531706" is the best.
Old Sep 13, 2017 | 05:59 PM
  #3433
jimersees's Avatar
Hi guys
I have sent a donation to tephra a while ago in regards to a rom that I'm looking for.
Rom I need is 88581713 for ADM Evo 9 With speed density.
Iv sent messages to tephra but his inbox is full. Does anyone have the above rom? Or can help me.
Kind regards
Jimmy
Old Sep 13, 2017 | 11:57 PM
  #3434
seeaich's Avatar
Originally Posted by jimersees
Hi guys
Rom I need is 88591713 for ADM Evo 9 With speed density.
Kind regards
Jimmy
Any specific reason you need that number and cannot use a 8859 varient?
First post has the 88591715 3d SD Rom that suits your car.
https://www.evolutionm.net/forums/ec...bles-baro.html
File Type: zip
File Type: zip
Old Sep 16, 2017 | 04:24 AM
  #3435
Evo8Emperor's Avatar
Hey guys Im in the process of a new build and curious if anyone could check out my rom ive been putting together.
A couple things to know. With the new build I had to get a new harness or the shop i had doing to work did anyway. The harness I ended up getting has no maf plug and I have no maf kicking around anyway in order to run car regularly.
So I need to run Speed Density to start off. I have the GM IAT sensor wired in to the maf wires. I am also running the Omni 4 bar MAP sensor.
Also had to find another ECU after the shop had already told me my original ecu was junk for what ever reason. They then went and got another ecu but were still not able to get car to start.
So I diagnosed the car with a friend after pulling it out of shop and came to a junk ecu again. Most likely because we found main grounds not connected by ECU and them cranking the car over constantly.
Now I just trying to make sure I have all the Speed Density settings correct along with the MAP sensor values which I am having a hard time locating actually.
Let me know what you guys think. I could start a new thread but just trying to get as many eyes on it as possible. Really like to hear this thing start sometime. lol.
