TephraMod V7
Old Mar 3, 2018 | 10:41 AM
  #3466
V.8MR's Avatar
... figured it out
Old Mar 13, 2018 | 10:42 AM
  #3467
Thrive's Avatar
Hello! Help me please. I'm search for the firmware 96536706 (3d VE + LiveMAP). Search in the forum did not help me. Please share this firmware and XML to it.
Old Mar 29, 2018 | 03:15 PM
  #3468
sandman121383's Avatar
hey everyone!
hope all is well!
is anyone or everyone still on here running tephra? this thread hasn't had as much action lately.
i'm running speed density 2.0. have some minor tuning to do to cure a rich condition at some load point....... hows everyone else doing!?!?!?
Old Mar 31, 2018 | 03:56 PM
  #3469
ug_orf's Avatar
Hello!
Still running V7 on my Evo7, doing great...
Old Apr 9, 2018 | 06:58 PM
  #3470
That's awesome. Good to hear. Anybody else still alive in this thread!?
Old Apr 9, 2018 | 08:02 PM
  #3471
seeaich's Avatar
Similar to you. running 2.0SD. just trying to get my cold driving ability like stock. everything else is smooth as butter
Old Apr 24, 2018 | 11:14 PM
  #3472
mikey77's Avatar
Evo 7 rom
Originally Posted by ug_orf
Hello!
hello can I ask which rom your using on the evo 7 trying to sort mine out,and are you running sd?
cheers mike
Old Apr 24, 2018 | 11:48 PM
  #3473
mikey77's Avatar
Evo 7 rom
Hello!
which rom are you using mate?
cheers
Old Apr 25, 2018 | 06:00 PM
  #3474
butte's Avatar
I have a question about migrating the MAF scaling. My stock ROM has a table named "Airflow/Hz Raw Scaling" where I've been adjusting the scaling up until now as well an "Airflow/hz Raw Offest" table. The Tephramod v7 seems to have only a "MAF Scaling (MAF Adder already included)" table.
My question is, how should I translate the values from my stock ROM table to the Tephramod table? Should the "MAF Scaling (MAF Adder already included)" table be populated by the sum of the scaling and raw offset values? I attached a pic if it helps anyone understand what I'm talking about. I've got it running on SD with some pretty high values but the load goes all out of whack under boost (1000+)
Edit: High load was because I was looking at mut2byte instead of the 1byte load with the proper correction factor. Still wondering about the MAF scaling though if someone could help.
Old Apr 25, 2018 | 10:17 PM
  #3475
mikey77's Avatar
Sd setup
hi mate sorry to jump on your question but what process did you do to get your car running in sd?did you simply flash a rom to your ecu wire your sensors in and it works or do you have to change anything in evoscan/ECUflash to be it to work and also where did you wire your map sensor into?im at a loss as I can’t get a reading off my map sensor.any help would be much appreciated
Old Apr 26, 2018 | 08:27 AM
  #3476
butte's Avatar
I downloaded the tephramod v7 ROM that supports speed density and I translated all of my values from the stock rom over to that. Still figuring it out to be honest, but I'm able to drive my car to and from work on (very low) boost
Rewiring wasn't necessary. I'm using the fuel temp for IAT at the moment and the same Omnipower 4 bar map sensor that i've been using for years. Are you having trouble reading your map sensor in evoscan? Is it the stock map sensor?
Old Apr 26, 2018 | 09:24 AM
  #3477
mikey77's Avatar
Tephra
thanks for the reply
is it necessary to copy over stock rom values just to test my map sensor is working and wired correct?iv already reflashed my ecu with a SD Rom ?
the map sensor I’m using is a gm 3 bar map sensor,all I want to do is just get my car fired up on sd so it can go to be tuned,where do you see the map reading in evoscan when data logging in the maf section.
thanks for any help
Old Apr 27, 2018 | 10:03 AM
  #3478
s4nd's Avatar
Hello,
mine is evo 9 gsr jdm, the rom is 89280002 , how can i use tephramods for this rom?
thank you
Old Apr 28, 2018 | 08:28 AM
  #3479
butte's Avatar
thanks for any help
I would install and test the new MAP sensor on a known good and working ROM before attempting to switch to SD
Old Apr 28, 2018 | 10:23 AM
  #3480
mikey77's Avatar
The rom iv downloaded has been used a lot so I know it’s good but all I want to do is check my map sensor is working and just try and start my car I won’t be driving it until it’s been tuned, I’m where do you see your map sensor reading in evoscan?
