TephraMod V7
Old Jan 4, 2018 | 11:45 PM
  #3451
D1andonlyantman's Avatar
Originally Posted by Klaiceps
88590715 is the one you need for your Evo 9.
I'll give it a go this weekend, thanks mate
Old Jan 6, 2018 | 08:59 AM
  #3452
I tried the rom today but the car wouldn't start it turns over but won't fire. I've copied the immobiliser and init code from my v5 rom. I set the "immobiliser hex" to EDM. Any ideas why it isn't starting?
Edit: changed the immobiliser settings and it fires up. Goes to 2k for a few seconds but then as the revs drop it dies. Probsbly because both of my desired ISCV tables are totally empty. There's not even a table there??
Another edit, apparently them tables aren't needed on v7. In that case, any idea why my car dies after a few seconds
Thanks
Old Jan 20, 2018 | 11:39 AM
  #3453
Evo__Lee's Avatar
When reading ECU flash I have an unknown rom image message... Where do I find the possible missing files, I've searched and found nothing... Also is there another possible reason via tuner as to why I cant upload my own rom image? any help would be appreciated...
Old Jan 20, 2018 | 11:52 AM
  #3454
I read and write in evoscan. Doesn't work in ecuflash for some reason
Old Jan 20, 2018 | 06:48 PM
  #3455
Evo__Lee's Avatar
when you've read the ECU in evoscan how did you view everything to actually edit what inside the rom?
Old Jan 21, 2018 | 01:32 AM
  #3456
In ecuflash mainly (or maptracer in evoscan sometimes), then upload in evoscan again
Old Jan 23, 2018 | 02:32 PM
  #3457
SeemoGP's Avatar
Hi, How do i get tephra mod on my evo 7
Old Jan 25, 2018 | 11:37 PM
  #3458
outrage_uk's Avatar
Hello everyone. Just learning my way round Evoscan / ECU Flash.
I have a 2004 Evo 8 MR 6 speed (JDM).
I believe I need the 96260009 ROM / XML (mine is 96260007).
I sent a donation to Tephra about a week ago, but ive had no reply. I wondered if someone with this ROM / XML could pm me and email me it, id be very grateful, im not sure Tephra is active with this stuff anymore
Cheers
Old Jan 26, 2018 | 09:10 PM
  #3459
CDrinkH2O's Avatar
You can use 96530706 if you want a V7 ROM. Instructions herehttps://www.evolutionm.net/forums/ec...6530706-a.html
Old Jan 27, 2018 | 04:17 PM
  #3460
outrage_uk's Avatar
Thanks, Ive tried the 0706 ROM and it doesn't play nicely with my Evo
Old Jan 28, 2018 | 03:07 AM
  #3461
400s's Avatar
In what way?
Old Jan 28, 2018 | 11:20 AM
  #3462
outrage_uk's Avatar
Ran pretty ****ty even after copying my big MAP over, and non of the mods seem to work EGR removal etc
Old Feb 18, 2018 | 11:39 PM
  #3463
outrage_uk's Avatar
Angry
Cheers
Someone must have the 96260009 files ? Tephra was last active on here on 7th Feb apparently but no replies to emails or on here
Quickly falling out with this car..
Old Feb 19, 2018 | 02:03 PM
  #3464
tephra's Avatar
just sent it to ya!
Old Feb 19, 2018 | 05:46 PM
  #3465
outrage_uk's Avatar
Thanks mate received
