TephraMod V7
Error code: https://www.evolutionm.net/forums/7251361-post1098.html
I've had good luck with the boost error stuff on 96531706, so not sure quite what's different between the two roms. Just use that one, you konw you wanna go speed density anyways
Is anyone having ECU-boost error problems with 96530706?
I just moved my personal 05 Evo over to 96530706 finally and am having issues with the logged boost error not working.
Boost works fine but if I have the rom set for PSI load error shows +19 (or whatever positive number maxed pegged and flatlined as soon as the car is WOT) or with Load , load error shows -20 ( or whatever negative number is pegged and flatlined)
I have both Load and PSI target tables set correctly.
Also. I ran around with the rom for a week with no idle error code and today I tuned the car on the dyno and now I get the TB idle error code every time.
Thanks in advance
- Bryan
Thanks in advance
- Bryan
https://www.evolutionm.net/forums/ec...trol-mods.html
Thanks for the link
- Bryan
1 ) Boost reads 2~ psi lower (when compared to my calibrated Zeitronix 3 bar map sensor and calibrated Mustang Dyno 5 bar Map Sensor) on the Omni 4Bar map sensor in EvoScan (I have changed the map settings like mentioned in Step 3b, MAP Sensor selection in the thread below and added the OMNI 4 bar entry for EvoScan):
I was looking at that... just not sure exactly what i need to copy over. Was hoping that either somebody already has and will post the XML or someone would post what to copy and paste.
Added to the recompile
88590715
Here is the recompile loaded with the SD tuning tables... I have not verified if this works yet as I have not started tuning the SD yet. But it should work. Just add the XML file to the ecuflash directory and then modify your ROM ID as explained below and the SD tables should pop up with all the MOD 7 stuff.
88590715
Here is the recompile loaded with the SD tuning tables... I have not verified if this works yet as I have not started tuning the SD yet. But it should work. Just dont replace your XML file until you are ready to start tuning SD. I dont know if this will effect the car with it still running the MAF
Go to the "ECU Internal ID" under the Misc section in ECUFlash and change 07 -> 17
save and close
Go to the XML and change the ROMID tag at the top from 88590715 -> 88591715
save and close. Now your SD Rom should show up with only SD XML and your regular rom with regular XML.
save and close
im not sure where the misc section is that you are referring to....
I cant edit anything under rom info without selecting the new map function. The xml part is easy and his been done on mine, but cant edit anything else
Thanks CWILL, i never noticed that...
88591715 is updated and uploaded with a quick set of instructions. Test at your own risk, but it works on my car. Now time to SD tune i guess...
