What could be the problem??
Old Oct 15, 2009 | 11:06 PM
ohhgyeahfasho's Avatar
Hey, my friend who isn't in the forum sent me a couple of logs to check out since his car wasn't running as strong as it used to. So I plugged it in JOT's Virtual Dyno and this came up. He has a 30R on race gas or E85(not sure which fuel) and has all bolt ons on stock clutch.
So, Is this how it looks like to have the clutch slipping on the JOT Virtual Dyno? If not, then what could be the problem? Thanks guys.
Old Oct 15, 2009 | 11:16 PM
tephra's Avatar
do you log speed?
plot rpm vs speed
Old Oct 15, 2009 | 11:19 PM
Originally Posted by tephra
do you log speed?
plot rpm vs speed
He wasn't logging speed. I'll ask him to log speed tomorrow. But can a slipping clutch cause that? The log showed tip in knock of 1 count and then disappeared, so it cant be a knock issue pulling timing.
Old Oct 15, 2009 | 11:21 PM
tephra's Avatar
could do...
but log speed vs rpm - if the line isn't straight (ish) then you know the clutch is slipping
Old Oct 15, 2009 | 11:26 PM
PaperClip's Avatar
You should know if the clutch is slipping. Engine free revs like crazy once you over power it. Mine would slip around full boost once it started to go. A slipping clutch would cause a drop in power cuz it wouldn't be putting the power to the tranny.
Old Oct 15, 2009 | 11:30 PM
tephra's Avatar
it wouldn't cause a powerdrop on a rpm based dyno tool like VDR
Old Oct 15, 2009 | 11:32 PM
could do...
Looking at the TPSvsRPM graph on EvoScan, it shows this..
Old Oct 15, 2009 | 11:33 PM
PaperClip's Avatar
I thought It would. I don't know how VDR works, but I thought those kind of programs calculated load into it and if the motor is free revving there wouldn't be as high a load on the engine so the hp output wouldn't look as high. Im not trying to argue as I am not sure how it works, just trying to help the best I can.
tephra's Avatar
nah they use how much time it takes to go through the RPM's.
nothing todo with load.
^^ that looks pretty screwed
still for educational purposes do the rpm vs speed thing
Old Oct 15, 2009 | 11:34 PM
VDR works with RPM, so the faster you rev the higher the power you'll get. Which is why my first guess was that his clutch was slipping because if you look at the graph the moment he hit full boost his power jumped up really high, then settles back down when his boost tapered off. My friend doesn't live near me so I can't check for myself.
Old Oct 15, 2009 | 11:39 PM
PaperClip's Avatar
Ahh, I see. Haha he should keep the graph and print it out so it looks like he has the mad whp
Old Oct 15, 2009 | 11:40 PM
His first logs didn't have this problem and looking at the RPM graph, it's very smooth and has no bumps. So I guess we can somewhat assume that this is indeed a clutch problem?
211Ratsbud
Nov 3, 2012 03:19 PM
Tmosser
Oct 24, 2012 11:28 AM
clockworktoy
Dec 11, 2011 12:20 AM
w8tless1
36
Jul 10, 2004 09:31 PM
