Map switching problem 8859 and 8858
Old Nov 3, 2012 | 01:13 PM
211Ratsbud's Avatar
I've tried both of these roms to work with the jot map switch. Neither works. Verified 4.7v coming to ecu pin. No dice. Tps map switch works fine but not what I'm after.
I should add that when I first installed this it did work for a week or so. Then it stopped. Maybe my ecu is bunk?
Whyyyyyyy?
Old Nov 3, 2012 | 01:19 PM
211Ratsbud's Avatar
How do I log voltage at pin 0f in Evo scan?
6b0d?
Old Nov 3, 2012 | 01:25 PM
donner's Avatar
Originally Posted by 211ratsbud
how do i log voltage at pin 0f in evo scan?
6b0d?
mut83 (6aed)
Old Nov 3, 2012 | 01:34 PM
211Ratsbud's Avatar
I get index was outside the bounds of the array
Old Nov 3, 2012 | 01:39 PM
211Ratsbud's Avatar
Thank you. Loose ecu pin!
Old Nov 3, 2012 | 02:45 PM
211Ratsbud's Avatar
Works great now
Old Nov 3, 2012 | 02:48 PM
todd6027's Avatar
tut tut
Old Nov 3, 2012 | 02:51 PM
211Ratsbud's Avatar
I'm not going to explain in detail what I did wrong .. But I skipped a step
I didn't remove the orange retainer I just pushed the pin in haste and duhh why wouldn't it come loose!
Idk why it didn't occur to me to do that since I was removing it on other plugs to repin egr to sas!
Old Nov 3, 2012 | 03:01 PM
todd6027's Avatar
it always the simple things that catch us out . any luck with the als ??
Old Nov 3, 2012 | 03:19 PM
211Ratsbud's Avatar
Workin on it I need to order a couple fittings from discount hydraulic supply. M16x1.5 -jic 12.
Now I have the switch working so one more piece in place.
Evo-IXse06
Jul 24, 2015 01:53 PM
Evo-IXse06
May 9, 2015 06:58 PM
stunt2
Aug 9, 2013 11:34 AM
SLO-EVO
AEM EMS
10
Apr 24, 2012 02:41 PM
catman78
Oct 5, 2011 03:42 AM
