Mut Sniffer
Old Nov 6, 2009 | 01:52 PM
Deepnine's Avatar
Mut Sniffer
Hi,
i have access to a mut2 and mut3 (mitsubishi diag tool). is there a sniffer app out there for openport 1.3 cable?
I would like to try sniffing all acuators and all logging items.
problem:
i can't write my own app. i tried, but my knowledge isn't big enough.
my idea is that i connect the openport cable and the mitsutool both to the obd plug on the car.
maybe someone can write a simple tool that displays all data sent from mitsu tool to the ecu and back.
like sniffing a network with a lan-adapter in listen mode.
i tried using hyperterminal but i couldn't get it workring.
any ideas?
Old Nov 6, 2009 | 06:28 PM
Ceddy's Avatar
I try something similar a while ago.
The problem I ran into was because two things were talking on the same line I got a lot of corrupt and miss aligned data. I had better luck with the with my FTDI cable pretending to be the ecu.
Can the MUT3 tool flash using .RPG files?
Old Nov 6, 2009 | 07:08 PM
infini_IV's Avatar
all genuine mitsi mut 3 reflash's and software upgrades are .rpg files
Old Nov 7, 2009 | 12:17 AM
Deepnine's Avatar
i dont know much about serial protocols, but isn't it possible to monitor only?
or to wire something between sniffer and the mut <-> ecu connection, that no data is sent from the sniffer.
Old Nov 7, 2009 | 05:51 AM
Ceddy's Avatar
The MUT Tool and ECU both talk on the K-Line, so its hard for for the Sniffer to know which one is sending/receiving and its easy to get alignment problems. I was looking mostly at the 5 Baud Init Sequences that switch to 10400 or 15625 Baud when done. You might have better luck if you just monitor the MUT 15625 stuff.
I wired a spare OBD2 plug to my existing one and hooked a 1.3 cable to that.
I used Visual Basic and the FTDI Library to make a "sniffer". I couldn't get HyperTeminal to work, don't think it can do 15625 baud or something, so I used another terminal program. I have source code for a MUT/Hybrid Logger project I never finished if you would like to see how the FTDI stuff works.
Old Nov 7, 2009 | 07:32 AM
Deepnine's Avatar
i think i can get the communication sorted out by hand.
if i monitor logging for one item, i get only one request value and different response values.
of cause i like to see some code, maybe i understand it and can modify it to work for me.
Old Nov 7, 2009 | 07:33 PM
Ceddy's Avatar
http://ceddy.us/wp-content/uploads/MHIScanner_FTDI.rar
Code isn't clean, but might help getting you to started with the FTDI/MUT comms.
Old Nov 7, 2009 | 11:38 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
what I would do is take 2 x MC33290, female, male OBD plugs and serial sniffer in-between
Old Nov 8, 2009 | 06:04 AM
Deepnine's Avatar
it's working.
i found a arduino board with a ftdi chip onboad. i used this chip as a sniffer with a 15625 baud compatiple terminal. i just connected the receive line.
the 12v->5v translation i have done with some resistors.
its a dirty thing but it works great.
now i am going to squeese out the last bit of information from the oem mut3.
i just need to build a more robust wiring for in car use.
thanks for you good thought, i have a lot of new ideas now.
Old Oct 24, 2010 | 07:48 PM
logic's Avatar
This thread has been dead for a year, but here's a quick suggestion for the archives: on a Linux host system, with Windows running as a guest in a VM (on any virtualization platform that allows you to pass through USB devices to the guest system), use Wireshark on the Linux side to capture the raw USB traffic on a given bus, then kick off whatever activity you want to capture on the WIndows guest.
You may need to do a little protocol analysis to get the data you're looking for depending on the device you're sniffing, but this got me 90% of the way there for what I was trying to do (and wireshark's awesome filtering got me the rest).
Old Dec 29, 2011 | 11:13 PM
yusrij's Avatar
it's working.
Hi Deepnine,
I am interested to know more about how you used arduino to communicate with ECU in MUT protocol. Currently, I have MUT ODBII cable but i do not have FTDI serial cable.
Just not to bother you with many question from me, can i have the sample of the arduino programming to communicate with ECU and how you make the wiring?
Thank you.
EyeDreamt
46
Mar 19, 2023 01:41 PM
d3m0n
Mar 30, 2017 07:13 AM
darkeye
Oct 2, 2015 09:47 AM
Danieln
Apr 15, 2010 05:04 AM
Malmoe_Sweden
Sep 17, 2008 11:23 AM
