**Need Help setting up V7???** Here is your answer
Old Nov 11, 2009 | 01:40 AM
Evo_Jay's Avatar
Originally Posted by Fast_Freddie
That is a minor issue to me, and I mean minor... also that isn't my thread so adding everything to the first page is not my decision...
Okay. I know, I was just saying.
Originally Posted by Appauldd
I am having major computer issues right now. Once I get everything worked out I will edit the OP and add the fixes.
As Freddie stated...the 2k rev is MINOR. Other than that the car runs like a champ. I am just **** and want to solve everything all the time.
Okay. Sounds good.
I understand it may be minor but its not normal, so a fix sooner or later may be good.
Old Nov 11, 2009 | 03:11 AM
Fast_Freddie's Avatar
Veteran: Navy
To me it is normal, as I noticed the same behavior with the 96940011 rom... so when Applaudd brought it up I was wondering what he was talking about
Old Nov 11, 2009 | 03:23 AM
Evo_Jay's Avatar
Oh well maybe it is normal......
Old Nov 11, 2009 | 09:42 PM
Jeff_Jeske's Avatar
Do other ROM hacks work with V7? For example I am using the REAR O2 DELETE CODE found here: https://www.evolutionm.net/forums/6727392-post117.html & https://www.evolutionm.net/forums/7302686-post267.html
I would like to run V7 without a rear O2.... or does the simulator already allow you to remove the factory rear o2?
Old Nov 12, 2009 | 01:44 AM
Veteran: Navy
You should be able to use both of the patches, however I have an VIII, and still physically have my rear O2 installed,just using the O2 sensor simulator routine included in V7, so i am not familiar with the second patch for the rear O2. Is the patch you linked to totally remove the sensor (patches the routine & the heater)?
Old Nov 12, 2009 | 06:06 AM
Jeff_Jeske's Avatar
Yes the patch I am referencing does allows the user to remove the rear sensor completely. There's also a round of patches the present the correct OBD2 variables when queried even if the equipment has been removed.
I'm always nervous about adding "outside" patches to tephra's roms as it may unintentionally change an area of memory that affects something else.
One more question.... Cold start timing retard (for cat efficiency).... I'm using 1.42 and do not see this map? I was lead to believe this was separate from the overly hyped bit 9/11. I am not looking to disable EGR but instead simply get rid of the cold start timing reduction.
Old Nov 12, 2009 | 06:19 AM
Veteran: Navy
Yeah i have the OBD II radiness patch on mine...no problems.
The table that you are looking for is the percent low temp timing trim map. then just zero that table out...
Old Nov 12, 2009 | 11:46 AM
SWOLN's Avatar
Curious if anyone is having an issue where, when you let off the throttle, the rpm stick at about 100-300, and bog a little with 88590017 ?
Old Nov 12, 2009 | 12:27 PM
donour's Avatar
I removed the rear 02 sensor by doing three things:
1) enable the rear o2 sim which is included in v7
2) disable the rear o2 heater check. Easy for 96530006, maybe easy for other roms, but I haven't looked around.
3) unplug the sensor at the passenger seat and remove.
d
EDIT: No DTC/CEL.
Old Nov 12, 2009 | 04:03 PM
Jeff_Jeske's Avatar
Okay thanks... its #2 that needs to be applied at the XML level to trick *** the DTC.
I'll try this tonight.
Old Nov 12, 2009 | 04:13 PM
Veteran: Navy
If you disable the rear O2 via periphery bits, then that also disables fuel trims from reading FYI.
Old Nov 12, 2009 | 04:21 PM
Jeff_Jeske's Avatar
I've never used the periphery bits.... just the code listed in my previous posts.
Old Nov 12, 2009 | 04:38 PM
alicea8541's Avatar
I am getting my ROM ready for PSI boost control. On the Global Boost Control, MUT8A and MUT8B show load and psi but don't include the hex code I need. Just has the 0x for both. The default is
MUT8A=DB6A
MUT8B=DA6B
Are these correct for setting up in PSI.
Old Nov 12, 2009 | 08:03 PM
Veteran: Navy
Sorry, I can't help you with any of this as I do not run ECU controlled boost...
Old Nov 12, 2009 | 09:39 PM
Jeff_Jeske's Avatar
Well I switched over to V7 tonight. Overall painless process.
EVO 9 - GM3PORT
1. I have a 2k rpm cold start that I never had before.
2. Very low idle when warm - lower than before
3. WGDC didn't follow along correctly or all the extra features are affecting the setting. Overall boost was lower with the new version.
4. Also not sure what to check to have an alt map via gas pedal sort of like valet on the previous versions.
