Increase Fuel pressure & Latencies
Old Nov 14, 2009 | 03:41 PM
Oracle1's Avatar
How does increasing the Fuel pressure affect the latencies, or does it?
Old Nov 14, 2009 | 03:48 PM
Slo_crx1's Avatar
"Technically" it doesn't...in a perfect world. However, as pressure increases against the pintle it takes longer to open due to the extra force applied. We're talking minute amounts though for smaller injector sizes, but once you start hitting the 1000cc range it can make a difference. Which is also why most large cc injectors use a disk style injector tip (Lucas usually) instead of a pintle type...lower latency time with the disk style.
Old Nov 14, 2009 | 03:58 PM
Oracle1's Avatar
would decreasing fuel pressure from 4 bar to 3.5 bar lean the idle on 1000cc injectors with the same latencies, does it also knock the fuel trims out?
Old Nov 14, 2009 | 11:41 PM
Slo_crx1's Avatar
Decreasing the base fuel pressure will affect the entire range.
Old Nov 15, 2009 | 07:38 PM
mrfred's Avatar
It would richen idle because the actual latency would decrease.
Old Nov 16, 2009 | 10:15 AM
Oracle1's Avatar
spot on! Some how it went rich, have no idea why? Strange.
Big Bald
Oct 11, 2013 08:13 PM
Anarchy99
Jul 17, 2012 04:00 PM
ecktt
Nov 2, 2010 09:54 PM
TouringBubble
Jul 2, 2008 05:30 PM
ct9a_mr
Jun 13, 2008 08:06 AM
