Stock Inj duty cycle
Old Nov 22, 2009 | 07:10 PM
PlanoEvo's Avatar
Just curious what is the max stock injectors will run in terms of duty cycle? I logged a couple of runs tonight and max duty was 102.96% with no knock. TBE tune MBC ETS 4inch IC Spoolinup COP at .030 gap Copper plugs
Old Nov 22, 2009 | 07:14 PM
FTY Motorsports's Avatar
i have heard people running at 110% but i would never do that for obvious reasons. just get bigger injectors and keep it safe
Old Nov 22, 2009 | 07:21 PM
PlanoEvo's Avatar
If you were to guess what boost would you think I was at?
Old Nov 22, 2009 | 07:26 PM
CMB's Avatar
CMB
26 psi
Old Nov 22, 2009 | 07:30 PM
PlanoEvo's Avatar
26 tapering to what would you guess...mbc....
Old Nov 22, 2009 | 07:31 PM
CMB's Avatar
CMB
21
Old Nov 22, 2009 | 08:23 PM
scheides's Avatar
EvoM Moderator
Why on earth would you guess how much boost you are at? Don't you have a boost gauge or upgraded MAP sensor? Very very foolish if you are tuning and have no way of referencing boost.
You should be able to do up to 115% or so w/o them going totally static, the stock turbo tapers pretty bad (in ref to power, not just boost) up top which helps this. With alky, I ran mine up to peak of 129% IIRC w/o issue.
Old Nov 22, 2009 | 08:39 PM
mine spikes 31.5 psi and tapers to about 26psi on a stock evo 8 turbo 9.8 hotside lol on MBC so take that
Old Nov 22, 2009 | 08:59 PM
JohnBradley's Avatar
IDCs have almost nothing to do with boost or power. I have seen 330whp cars at 102% and 374whp cars at 102%. VE and mods have a lot to do with how the car is going to react. A more accurate question would be what load is the car at when it is at 102.xx% and the math is pretty easy.
Old Nov 22, 2009 | 11:34 PM
Cronic's Avatar
yah I see 110% often @ 25psi
Old Nov 23, 2009 | 04:40 AM
EvoIan's Avatar
I too have seen 100-105% fairly often. Injectors will be needed soon but not on my current setup.
Old Nov 23, 2009 | 05:05 AM
eTiLiKo's Avatar
So I must assume that there is something wrong with the IDC showed in evoscan (I have always assumed it). Because if we pass 100%IDC the AFR must go leaner because we are out of control of the injectors.
Old Dec 5, 2009 | 08:38 AM
PlanoEvo's Avatar
easy can you explain john to lesser knowing like myself
Old Dec 5, 2009 | 10:52 AM
Peak load and load at lets say 7500-8000. A stock MAF car on gasoline (octane limited) will have a load level that corresponds to the estimated hp formula I implemented with Eric's help so long ago.
For instance if you are at 102% and only 190 load at 7500, the formula looks like this:
190 (load) / 95 = 2 (g/rev) * 7500 (rpm) / 454 (constant) = 33.04 (lbs/min)
33.04 * 9.15 (apparent constant for DJ numbers)= 302whp
Now if we repeat the same thing with higher load (better VE and more power) we get
220/95=2.315*7500/454=38.256*9.15=350whp
Both values can be 102% but because the car is breathing better from cams, exhaust, whatever it makes more power as is reflected in more load. Strange but true.
https://www.evolutionm.net/forums/ec...hp-torque.html
Old Dec 5, 2009 | 02:49 PM
PlanoEvo's Avatar
thanks which extra boxes do I need to check in 2.6 to view load? Currently I have checked Throttle position,rpm,batt level,tim adv,IPW,IDC,and knock.
