FIC 2150cc notes
Old Dec 5, 2009 | 06:16 PM
  #46
Force-Fed Performance's Avatar
Are you using a surge tank then? or have a cell in the trunk. I believe im going to say screw it on my street car and put a 12-15 gal cell in the trunk and just run my own lines with a 2035 pump and just re wire the sending unit
Old Dec 5, 2009 | 06:23 PM
  #47
JohnBradley's Avatar
Modded stock hat, -8 Feed to the pump, -6 from there to the rail. Then the stock feed as the return.
Picture of it obviously unfinished. I will work on getting some undercar of the whole deal for those that want to compliment their size huge injectors. More less its common sense from that point forward though.
Old Dec 5, 2009 | 06:24 PM
  #48
I also contemplate this but the above poster DSM25psi was doing the same thing but his stock return line was backing fuel up into the cylinders
Old Dec 5, 2009 | 06:25 PM
  #49
dsm25psi's Avatar
thats what im going to get, thanks for the help
Old Dec 5, 2009 | 06:26 PM
  #50
dsm25psi's Avatar
i guessthe pump i got now is really for carb engines not made to flow high psi thats why i had so much problems on it running out of fuel on top
Old Dec 5, 2009 | 06:29 PM
  #51
dsm25psi's Avatar
yeap, got 6an return and now is all good
Old Dec 5, 2009 | 06:33 PM
  #52
Stock return is dreadfully small and can get overran rather easily. I think the lowest mine would flow was 55-60psi.
Old Dec 5, 2009 | 06:35 PM
  #53
Well Tim(dsm25psi) i really believe you need to be on a weldon or fuel lab pump man/ take out the evap canister and just run you a big feed and return, course with what im doing i may have to run a -10 all the way up and a -8 all the way back
Old Dec 5, 2009 | 06:40 PM
  #54
dsm25psi's Avatar
yeap diff pump
Old Dec 5, 2009 | 06:44 PM
  #55
There is also the 750 Pro tuner which is the biggest of the street pumps then the 750 eliminator or something which is what is in our drag 1G. Evo is going full mechanical this time around.
Old Dec 5, 2009 | 07:09 PM
  #56
Colt4g63's Avatar
Originally Posted by JohnBradley
We made 766-774 on Lucas' car with these injectors on E98. I tuned Big Jesse's car to 665 at 66% on Q16 on 1450s. Lucas was out on the 1450s and dual pump at 698 (going static out the top) but has since revised his fuel system some so it might have been stable. It had been a 255 intank feeding an 044, now its dual 044 in parallel.
Lucas car on the 1450s at 698whp was that on E98 or out of the pump E85?
Old Dec 5, 2009 | 07:37 PM
  #57
That was no more than E85 and I think maybe was as low as E75 (mixing with Q16).
Old Dec 5, 2009 | 08:54 PM
  #58
dsm25psi's Avatar
thanks for your help, im going to get the same fuel pump
Old Dec 5, 2009 | 09:07 PM
  #59
Colt4g63's Avatar
Wouldn't regular "E75" take less fuel then E75 cut with Q16 as Q16 requires more fuel system over gasoline due to the oxygenation of Q16? I know i have seen a decent increase in fuel need for Q16 over C16 for obvious reasons.... Not sure how it really compares with mixing Q16 to the crap gasoline they cut our out of the tank E85 with though... Which im sure right now is E70 due to winter blend being in full effect here.
Basically im trying to decide which way i need to go 1st with my fuel system. By looking at my fuel map i don't see the signs of losing fuel pressure ATM just running out of injector.... BUT i also haven't looked at the FP under a WOT pull yet to see for sure what its doing.....
Old Dec 5, 2009 | 09:16 PM
  #60
GotWheelHop's Avatar
Can't use these 2150's with Q16 unfortunately.
