looking at ignition retard limit control, need some logging assistance
Old Dec 9, 2009 | 08:04 AM
mrfred's Avatar
I know that tephra has done some work on extending the ignition retard limit, but in the process of going through the ignition retard limit subroutine to understand what's happening, I think that there may be a way to more consistently approach -20 deg (or more). To start, I need someone (or a few people) to log a RAM variable during "launch conditions"
Evo 9 8859: FFFF6DC3
Evo 8 9653: FFFF8BF7
You'll have to write the value (e.g., 0x6DC3) to the MUT table and then setup a definition in the EvoScan Data.xml file.
Old Dec 9, 2009 | 09:44 AM
JohnBradley's Avatar
M,
I am assuming we just need to use a timing alg for the EvoScan def?
Old Dec 9, 2009 | 10:19 AM
mrfred's Avatar
Originally Posted by JohnBradley
M,
Raw (eval="x") is fine.
Old Dec 9, 2009 | 11:40 AM
I should be able to get something later today for you then.
Old Dec 9, 2009 | 12:39 PM
mrfred's Avatar
Thank you!
Old Dec 9, 2009 | 12:58 PM
scheides's Avatar
EvoM Moderator
I set MUT83 to 0x6DC3 and then setup evoscan to log requestID 83, that's it right? Or is there a better MUTXX value to use?
Old Dec 9, 2009 | 01:00 PM
l2r99gst's Avatar
scheides,
Are you using LiveMap? I thought I remember seeing you post about using it.
If not, disregard, but if so, it's as easy as putting the RAM address in your RAM mut table and logging using the LiveMap app.
Old Dec 9, 2009 | 01:09 PM
scheides's Avatar
EvoM Moderator
Nope, old-skool evoscan and restarts/reflashes here I don't do enough tuning to jump to livemap, but hey, it's winter--might find myself trying it out here soon
Old Dec 9, 2009 | 03:18 PM
mrfred's Avatar
MUT83 is fine as you described, and then use Eval="x".
Old Dec 9, 2009 | 05:48 PM
ziad's Avatar
i will test... seeing i got 9653 and wanting to test my stat rev limiter
Old Dec 9, 2009 | 07:58 PM
scheides's Avatar
EvoM Moderator
I couldn't get timing to go to -20, I'm using the off-the-shelf 96531706 rom, but that value stayed at 195 solid during all driving and bouncing off the launch control rev limiter.
Old Dec 9, 2009 | 08:04 PM
Appauldd's Avatar
I can't get mine to go past -10. Not that it would make a difference...I spin the heck out of the tires trying to launch this way. Sure is fun though.
Old Dec 9, 2009 | 10:29 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Nice work mrfred, I see where you are heading, those tables are also an open point for me
Old Dec 10, 2009 | 07:28 AM
scheides's Avatar
EvoM Moderator
Turns out I only had -20's in half of my map so timing was bouncing around. Set top half of map to -20's and re-ran (I called this value you're looking for RevLimContVar:
side note: is this high knock count normal?
Old Dec 10, 2009 | 08:15 AM
mrfred's Avatar
After looking over the timing limit subroutine a little more last night, I'm beginning to think that those tables are not so valuable. Ultimately, that limit of #203 needs to be increased to #231 to allow -20 deg. People are reporting momentarily reaching -20 deg and then tapering down to around -15 to -10 deg. There is something going on that's pulling r2 down from 231. It must be that bit of math and comparison that takes place after constraining r2 to the limit value.
BTW, you saw that the final RAM value at the end of the subroutine only serves to monitor timing via MUT and OBD? Its the second-to-last RAM value that appears to be the timing value used by the ECU.
