logging works, but can't read/write...
Old Dec 18, 2009 | 04:36 AM
crcain's Avatar
Switched a friend to Tephra 5.1 last night who wanted the flash CEL on knock and a couple other things. After I flashed the Tephra rom, I tried to write a couple small changes and it failed half way through a write, the error said retry the write. I did, and after that I got the error right at the beginning of when it starts the process, no response to any known codes after "sending init sequence" msgs.
One thing I did that I thought might have been a bit sketchy, is that I along with things like fuel and timing from my friends old map, I copied and pasted the entire MUT table from his previous rom to the Tephra 5.1 rom. I was unsure of copying and pasting was ok for that kind of table. Could that have caused the problem?
Battery voltage at idle for his car was 12.6 which I thought should be plenty to flash, not sure though. I also tried my friends OP2.0 cable and no luck.
Any suggestions?
Also, are all Evo 9 ecu's the same hardware wise? Meaning could I use an RS or GT ECU with a GSR? I'd like to try an ECU swap if we don't have any luck.
Old Dec 18, 2009 | 04:50 AM
crcain's Avatar
Forgot to add it's a JDM Evo 9 GSR and I use EcuFlash 1.42 with OP2.0.. rev C I think.
Old Dec 18, 2009 | 05:08 AM
MR Turco's Avatar
have you tried flashing with the unlocker? Is the pig-tail OBDI cable plugged in?
Old Dec 18, 2009 | 05:25 AM
crcain's Avatar
Have not tried the unlocker.. could you tell me how that works? I've never had to use it.
Also yes I triple checked the pig tail and also used a friends OP2.0 cable just to see if it was a cable problem.
Old Dec 18, 2009 | 05:39 AM
MR Turco's Avatar
you can find it on activematrix. It basically forces a read or write. I would suggest trying to force a read before attempting a write.
Old Dec 18, 2009 | 10:43 AM
crcain's Avatar
Do I need to be running EcuFlash 1.28 as the program says when I run it?
Old Dec 18, 2009 | 11:18 AM
MR Turco's Avatar
i dont believe so, i am pretty sure i have run it on 1.42. Again, i would try a read first.
ecktt
Apr 19, 2015 02:20 PM
awdordie
Apr 20, 2012 10:20 PM
bleunetizen
Feb 20, 2011 01:19 PM
Evo8Emperor
Feb 4, 2009 01:19 PM
