TPS help
Old Jan 10, 2010 | 08:08 PM
shiftndeesgears's Avatar
TPS help
ive been logging since i bought my tatrix and havent been hitting 100%tps throught whole pull. any ideas?
Old Jan 10, 2010 | 08:45 PM
coulsnt be a bad sensor already could it? 34k miles
Old Jan 10, 2010 | 08:49 PM
Appauldd's Avatar
From the factory the TPS most likely won't hit 100%. It is simply set that way. You can adjust it to log and see 100%, There are 2 screws that hold the TPS in place. Just loosen them up and turn the TPS very slightly. Log the event with the ignition on and the car not running. You can see the TPS hit 100%.
But it isn't necessary, the ECU will interpolate what is WOT and what isn't any how.
Old Jan 10, 2010 | 08:51 PM
Appauldd's Avatar
Also....you might want to adjust the throttle cable a bit. There is a lot of slack in it from the factory. Be careful not to over tighten the cable though.
Old Jan 12, 2010 | 06:59 PM
thanx
Old Jan 12, 2010 | 07:36 PM
rolly1818's Avatar
Registered User
i hit 100% through all my WOT logs. idle = 13.33% if i remember correctly.
kamote2000
Feb 28, 2017 03:35 PM
kamote2000
Sep 30, 2016 10:50 PM
jb988
Jul 4, 2016 06:30 PM
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 4, 2015 07:02 PM
