v7 REV LIMIT not working
Old Feb 1, 2010 | 07:10 AM
  #46
fostytou's Avatar
EvoM Community Team
I believe FCA Bit15 is emissions related
P0443, P0446, P0403,P0243, P0090, P2263
(from my EGR removal thread... "Change periphery 2 (FCA) bit 15 & 14 & 13 to 0 (to disable EVAP checks if you removed these solenoids)" )
Old Feb 1, 2010 | 07:12 AM
  #47
Appauldd's Avatar
Yup...that is why I have it disabled.
Old Feb 1, 2010 | 08:30 AM
  #48
chmodlf's Avatar
If mine is working and yours is not, maybe we should compare the two roms. I have a hex compare tool on one of my machines...I think.
Old Feb 2, 2010 | 07:23 PM
  #49
tephra's Avatar
Can we get some closure on whether the 96530706 revlimiter works?
From a code point of view its the exact same as 88590715 - so I can't see a problem...
Old Feb 2, 2010 | 07:25 PM
  #50
l2r99gst's Avatar
I've never had any problems with them working.
Old Feb 2, 2010 | 07:46 PM
  #51
logic's Avatar
Ditto. I'm unable to re-check right now as the car is down, but I recall having no trouble whatsoever setting the stationary rev limit to whatever I needed for launch map testing.
As for the actual rev limiter, I can't say one way or the other. That's not something I test regularly.
Old Feb 2, 2010 | 08:03 PM
  #52
Appauldd's Avatar
I switched to the "new" rom. Rev limter and stationary both work great now.
Old Feb 3, 2010 | 02:38 PM
  #53
GST Motorsports's Avatar
Works just fine on my personal 05 Evo with 96530706. I have no issues what so ever running 9653 other then having to turn off the Idle test CEL, and the PSI/LOAD settings incorrect in the XML.
I just took a drive from sea level to 10,000 feet the last two days as well. No issues at all.
- Bryan
Old Feb 3, 2010 | 03:17 PM
  #54
tephra's Avatar
ok hopefully Appauldd works out the problem and updates post #1
Old Feb 4, 2010 | 07:09 AM
  #55
logic's Avatar
Per the discussion in the 9417 thread, I suspect he's done with 9653 at this point.
Scanning back through the thread, it looks like evo8dad and 3gEclipseTurbo also reported the problem; if either of you guys are reading this, can you weigh in?
Old Feb 4, 2010 | 07:13 AM
  #56
Appauldd's Avatar
Yeah, you are right....I did switch to 94170715. The issues is completely resolved for me.
I apologize for not following through with this thread, but I am concerned for the safety of my vehicle and do not want to risk over reving and causing severe damages. I hope you can all understand.
Old Feb 6, 2010 | 01:24 PM
  #57
evo8dad's Avatar
I haven't tried the fixes yet. Will do soon.
Applaudd - the new 94170715 that has been released, is it SD compatible? I assume it has the v7 stuff included as well?
Old Feb 6, 2010 | 01:51 PM
  #58
evo8dad's Avatar
Nevermind - I just downloaded 94170715 and saw it is not SD compatible.
Tephra - I'll log the requests your asking for on a non-SD car as well as a SD car and post up the results. I can do the non-SD car tomorrow but, the SD car will have to later next week (needs a new battery). Hopefully this will give you some insight into what's up with this issue as I'd rather stay with the 9653 ROM.
Old Feb 9, 2010 | 07:03 AM
  #59
evo8dad's Avatar
I wanted to log mut00 & 01 but, couldn't get it to log. What is the correct .xml entry I should have in the data file?
Old Feb 9, 2010 | 07:09 AM
  #60
Appauldd's Avatar
I have
9653
01 = 8450
02 = 8451
9717
01 = 895c
02 = 895d
