Flashed to 9417 v7 now car won't start
Old Feb 7, 2010 | 11:08 AM
logic's Avatar
You're getting flashing errors. Ignore the rest of the hardware on your car (ie. your CDI), you need to address that problem first.
You said you've had voltage problems before (ie. had to charge the battery to get a flash to take). Hook up the charger to the battery, let it sit for a while, and try reflashing the car with the charger still connected. You absolutely, positively have to have nearly 12V for a flash to succeed, because the cable boosts the voltage to 16V on the flashing connector, and it's a bit of a stretch to make it happen.
Ignore everything else until you resolve those readback errors. If you've been getting those errors the whole time, then you have not been successfully flashing the car.
Old Feb 7, 2010 | 11:26 AM
Jorge T's Avatar
I just had a succesful reflash with a stock rom, just changed the Immo. still no start.
I can hear the fuel pump prime during start cycle but fuel never ignites. I will try again with the charger on at 10 amps.
Old Feb 7, 2010 | 12:39 PM
Jorge T's Avatar
tried again with charger on the battery. voltage was 13.95-14.1 during flash. Still NO GO. Immobilizer code checked over and over...how do I disable the immobilizer?
Old Feb 7, 2010 | 12:45 PM
logic's Avatar
http://evoecu.logic.net/wiki/Immobilizer_Disabling
Old Feb 7, 2010 | 01:00 PM
Jorge T's Avatar
Thanks, according to the wiki my periphery was labeled wrong, had bit 2 as immo instead of bit 3. time to try again.
Old Feb 7, 2010 | 01:02 PM
tscompusa2's Avatar
if that dont work, make sure the valet mode rpm is set high like 5-6krpm so it allows the car to crank over. theres a bug where if the valet mode rpm is to low it wont fire up.
Old Feb 7, 2010 | 01:08 PM
Jorge T's Avatar
disablin the immo did not work either.
tscomp, I'm back to 9417008 stock rom with my mods. so I have no valet mode.
was there something about once you upgraded to 94170015 you could not go back to 0008 or was that just myth?
Old Feb 7, 2010 | 01:23 PM
tscompusa2's Avatar
your car wont even fire up on the rom it did last time?
Old Feb 7, 2010 | 01:24 PM
tscompusa2's Avatar
give me your rom @ tscompusa@gmail.com and email me your immob code and i will fix it and you can retry it.
Old Feb 7, 2010 | 01:32 PM
Jim in Tucson's Avatar
I'm understanding that you had NO flashing errors on this ROM load? Correct? Sounds like the issue may not be ECU related after all.
Old Feb 7, 2010 | 01:37 PM
Jorge T's Avatar
Thanks I just sent it..yep it wont fire up on the old rom id did the last time.
Old Feb 7, 2010 | 01:39 PM
Jorge T's Avatar
It may well be , but what could of gone bad between a reflash that will keep it from starting?
Old Feb 7, 2010 | 01:45 PM
I had some flashing issues a couple years ago and could not figure it out and finally replaced the battery. Not saying that is your issue. But Logic is correct, the ECU needs a certain voltage, and perhaps amperage, to flash properly.
Also remember, if your starter is dragging a wee bit, and drawing too much voltage and/or amps, that means there is just that much less your ignition and ECU has to work with.
Old Feb 7, 2010 | 02:31 PM
Jorge T's Avatar
I just flashed a v7 from tscompusa and it was a no go. Battery is new so cranks really strong. I'm going to look at the fuses...
Old Feb 7, 2010 | 02:54 PM
1killertsi's Avatar
Check the main fuse onder the hood.
