Flashed to 9417 v7 now car won't start
Old Feb 7, 2010 | 05:39 PM
  #31
tscompusa2's Avatar
also use evoscan and see if you can actually control your car with it still.. activate the fuel pump and see if the relay kicks it on etc
Old Feb 7, 2010 | 06:52 PM
  #32
Jorge T's Avatar
I checked all the fuses, I can activate all actuators test with evoscan. Fuel pump and fans turn on. Its like the ignition circuit is dead or something set the immo in no start mode.
its deader than a door knob.
Old Feb 7, 2010 | 07:10 PM
  #33
dude's Avatar
I had a 10A fuse under the hood blow and couldn't start the car no matter what I tried. Changed the fuse, and everything was all good.
Old Feb 7, 2010 | 07:17 PM
  #34
Jim in Tucson's Avatar
Have you tried pulling a spark plug out to confirm there is fuel getting into the cylinder?
Have you tried pulling off a spark plug wire, attaching a free spark plug, and holding the threads of the plug against a ground whilst cranking to confirm spark? Use wood or plastic tongs!
May need to crank it with garage lights dimmed to see spark. Should be able to hear spark as well.
  #35
Appauldd's Avatar
Jorge....pm'd u
Old Feb 8, 2010 | 12:47 AM
  #36
Jorge T's Avatar
I checked all, except for the 2 pair of 10 amp held by a yellow plug, I could not figure out how to remove them.
Today a freind is coming by I will try my ecu in his car.
Old Feb 8, 2010 | 05:33 AM
  #37
Appauldd's Avatar
The pair in the yellow plug can only be pulled by using a pair of long needle nose pliers.
Old Feb 8, 2010 | 08:47 AM
  #38
Jorge T's Avatar
Well well It's not the ecu. I tried mine in my friends evo and his started right up with my ecu.
put it back in chenaged the immo to mine and still no start.
I'm changind the cdi for stock and checking for spark. any other ideas?.
Old Feb 8, 2010 | 08:55 AM
  #39
Appauldd's Avatar
Catch me on AIM or Google chat.....same SN as here....we can discuss it.
Old Feb 8, 2010 | 09:09 AM
  #40
Jorge T's Avatar
ok going to the store to buy fuses...got fuel but there is no spark
Old Feb 8, 2010 | 09:12 AM
  #41
Appauldd's Avatar
Don't forget we have 2 fuse boxes...one under the dash behind the knee cubby tray and the other under the hood.
Old Feb 8, 2010 | 10:22 AM
  #42
Jorge T's Avatar
all the fuses under the hood are fine, going under the dash...
is there an ignition coil?
Old Feb 8, 2010 | 10:32 AM
  #43
Jorge T's Avatar
FARKING ingnition coil fuse! It looked fien , I got a fuse tester and when I went back to check it did not pass the test.
Thanks guys for all your help...I new it had to be something stupid
Old Feb 8, 2010 | 11:08 AM
  #44
Appauldd's Avatar
WOO HOOOO ! !
Jorge T is on the road again. : )
Old Feb 8, 2010 | 11:20 AM
  #45
ixbreaker's Avatar
so where exactly is this ignition coil fuse? under the dash or the hood? Was it just a coincidence or did the flash somehow damage that fuse...in other words, why did the fuse blow in the first place?
