Trying to scale my new injectors
Old Feb 24, 2010 | 07:18 PM
xmaciek82x's Avatar
So for the last couple days I been reading and reading and reading....
Today I pulled the trigger and installed my PTE 780cc injectors.
I took Fostytou's setting from the "how to scale injectors" thread
PTE 780cc
Scaling: 680
Latency:
4.6875 3.624
7.03125 1.992
9.375 1.344
11.7188 0.984
14.0625 0.744
16.4062 0.576
18.6768 0.456
First when the car iled for about 30 minutes my Low LTFT got to about -7.5%. I increased the injector scaling to 696 and I did not pass -3.9%.
I figured that was good enough and went for a 30 minute cruise on the highway. My mid LTFT was way off, I got to +9.8%.
This is where I get confused on what to do next. Can someone steer me in the right direction?
Also my STFT is all over, at cruise, it ranges from -17% to +15%, and at idle -3% to +7%.
Any help would be great
Current settings:
PTE 780cc
Scaling: 696
Latency:
4.6875 3.624
7.03125 1.992
9.375 1.344
11.7188 0.984
14.0625 0.744
16.4062 0.576
18.6768 0.456
Old Feb 24, 2010 | 07:27 PM
JohnBradley's Avatar
What does your target AFR look like at WOT? If its in the 10s to mid 11s out the top then everything is pretty close and I wouldnt worry about it. If its off one way or the other you need to look at it all over again.
FOR INSTANCE-
I see a map that is 10.1 from 140-300 at 3k and 11.5 at 8k straight across.
You have a map that is 10.8 from 140-300 at 3k and at 8k its 12.3 straight across, you are a little too rich and the scaling needs to go up and you need to play with the latency. Cruise and idle are ALWAYS latency when you get it close at WOT.
The next thing is if the trims are close enough cool, if they arent it throws a light. Striving for perfection with a system that was designed to be flexible because of altitude, humidity, and temp is typically fruitless. Get it close and dont worry about it after that.
Old Feb 24, 2010 | 07:37 PM
xmaciek82x's Avatar
Can't do any WOT pulls. We are getting couple inches of snow at I type
Once I can do some WOT pulls I will let you know.
Old Feb 24, 2010 | 07:42 PM
l2r99gst's Avatar
Did you change anything else with the injectors? Do you have your breather hose connected to your intake pipe? Are you venting your BOV? Are you sure you have no vacuum/boost leaks?
If no for all of those, the easiest thing to do is check the scaling of the injectors via your AFR at WOT. Match your stock injector AFR.
Then see what the LTFT Lo + STFT is at idle and LTFT Mid + STFT is at cruise. Use latencies to adjust as good as possible (latencies will affect idle more than cruise). If both trims are still very far off from each other, use the latencies to get the LTFT Mid in line and then use the maf scaling table to get the LTFT Lo in line.
Old Feb 24, 2010 | 08:56 PM
xmaciek82x's Avatar
I think I'm an idiot...
I had EvoScan injector scaling still set to 513 when I did the logging. That needs to be set to 696 to get correct readings correct?
Old Feb 25, 2010 | 02:44 AM
Drill_Sergeant's Avatar
Veteran: Army
thats only for logging 1-byte load, im pretty sure
Old Feb 25, 2010 | 07:37 AM
hellcat's Avatar
No, it will effect the logs.
Old Feb 25, 2010 | 08:26 AM
travman's Avatar
The only thing that injector scaling value seems to be used for is the loadcalc formula - so if your not using loadcalc then it doesn't matter.
That scaling value in evoscan has zero impact on the fuel trim data....
Old Feb 25, 2010 | 10:58 AM
xmaciek82x's Avatar
^ Gotchya.
Old Feb 25, 2010 | 12:52 PM
Boosted Tuning's Avatar
I think that the injector scaling value also matter for logging Injector Duty Cycle correctly.
OP, PM if you need any help scaling your injectors.
Old Feb 25, 2010 | 07:11 PM
GST Motorsports's Avatar
No it doesn't, look at the Evoscan functions for IDC and IPW to see.
- Bryan
Old Feb 25, 2010 | 07:46 PM
- Bryan
Good to know.
Old Feb 25, 2010 | 08:39 PM
xmaciek82x's Avatar
Well I changed the scaling in EvoScan for 696 and my STFT and Low LTFT are all within 4%.
I did not have time to go for a 30 minute ride yet, but I have a feeling my mid LTFT will also be good.
I will keep you guys updated.
Fast_Freddie
Oct 30, 2023 01:56 AM
Yamahar1
Jun 1, 2010 08:47 AM
KOTT
Jul 15, 2008 05:15 AM
RedLanEVO
May 24, 2008 12:17 PM
cpoevo
Aug 21, 2006 07:31 AM
