Is it safe to customize your ROM INFO in the xml..
Old Mar 7, 2010 | 09:18 AM
lancebin's Avatar
Hi folks,
I'm wondering if it's safe to customize your own rom info on the xml file. For example i'm using an evo 8 box in my evo 6:
<romid>
<xmlid>96420008</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>96420008</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2004</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
Is it safe to change it to the following for example:
<romid>
<market>Test version</market>
<submodel>Evolution VIII</submodel>
<year>2004</year>
</romid>
Thanks!
Old Mar 7, 2010 | 09:35 AM
LGshow19's Avatar
You should have a problem. its not like your changing values or anything.
Old Mar 7, 2010 | 09:40 AM
psphinx81's Avatar
shouldnt be an issue..
Old Mar 7, 2010 | 10:02 AM
lancebin's Avatar
Ok thanks! just wanted to make sure.
Old Mar 7, 2010 | 12:47 PM
codgi's Avatar
What are you trying to accomplish is the real question.
Old Mar 7, 2010 | 01:49 PM
Ceddy's Avatar
The following can be changed without issue:
<make> <market> <model> <submodel> <transmission> <year>
The others you shouldn't mess with unless you know what your doing.
<xmlid> <internalidaddress> <internalidhex>, can cause your rom to use the wrong definition or not find the definition. Or cause xml "loops".
<flashmethod> <memmodel>, will cause a bad read or not read at all. On the H8 Evo5/6 ecus, you can brick the ecu with the wrong <memmodel>. Not sure if the Evo8 ecu will brick or just not write, but I wouldn't mess with it either way.
Old Mar 7, 2010 | 06:12 PM
lancebin's Avatar
Ok thanks for the detailed answer Ceddy, that answers my question.
Codgi:
I was just wondering if it would be safe to edit those values really.. like maybe later on a customer may want to have it tailored to fit his vehicle or something..
Old Mar 7, 2010 | 06:45 PM
codgi's Avatar
Codgi:
Fair enough. I guess that would only matter if you also give them the xml to go along with the flash. If you're going to keep this xml yourself (as most tuners seem to do) you won't get much benefit out of changing even the non-harmful ones.
Hiram6g74
Feb 22, 2018 03:00 PM
lexa609
Lancer Engine Management / Tuning Forums
Oct 3, 2016 12:48 PM
Panky
Jun 10, 2015 02:55 PM
tscompusa2
Aug 25, 2009 04:03 PM
evo L
Dec 28, 2007 05:34 PM
