Can't flash or read the ROM from your ECU - Start Here!
Old Nov 20, 2019 | 12:44 PM
  #106
pmlegend's Avatar
Thanks for your assistance. Bugger, have to get a 2.0 cable then. I have checked and chip is MH7202F. All i want to do is disable the immobiliser in ECU because I bought the engine and ECU separately to the vehicle.
Old Dec 17, 2019 | 12:33 PM
  #107
pmlegend's Avatar
I have purchased a 2.0 cable and successfully downloaded the rom from my ecu. The problem now is I cannot find any definition files for my vehicle. If I can find out the address of the immobiliser in the .bin file can I directly edit the entry and then reflash? Or does anyone know of definition files for 6g72, ECU rom MH7202F? Any help is most welcome.
Old Dec 18, 2019 | 04:06 AM
  #108
WytWun's Avatar
I've attached a basic definition which will give you access to the immboliser after you find the ROM ID. You will need to use a hex editor (I used HxD) on the ROM file to find the hexadecimal values for the 4 bytes at offset 0x21A through 0x21D. With that you then open the attached XML file in a text editor (I use Notepad++ but Windows Notepad should work) and replace the value "22490005" in the 3rd and 5th lines of the definition file with the 4byte hexadecimal code. The value in your ROM should be "2???000?" where the "?" characters need to be replaced by hexadecimal values (without the leading "0x" commonly used by programmers like me).
There's at least one person on this Australian forum who has done some work on definitions for an NL Pajero ROM which has similarities to the V6 MK Triton ROM.
File Type: xml
Old Dec 18, 2019 | 12:48 PM
  #109
pmlegend's Avatar
Thanks WytWun. I will try that and see how I go.
Old Jun 11, 2021 | 08:54 AM
  #110
edgariedtek's Avatar
hellooo
good morning someone here knows where I get the definition of a mitsubishi mirage1999 1.8L thanks
Old Sep 25, 2021 | 11:10 AM
  #111
evo_shibby's Avatar
Resolved.
Old Nov 27, 2021 | 08:08 PM
  #112
ODPR's Avatar
Originally Posted by waskarn
I use tactrix openport2.0 with LANCER EX 2009 GT 2.0 CVT
what happen I incorrect? Please help me.
[19:22:07.366] EcuFlash Version 1.42.2595
[19:22:07.366] OS Version Windows Vista
[19:22:07.366] Qt Version 4.5.0
[19:22:07.375] 56 memory models read.
[19:22:07.375] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[19:22:07.782] 447 ROM metadata models scanned.
[19:22:07.782] checksum module "subarudbw" loaded.
[19:22:07.782] checksum module "mitsucan" loaded.
[19:22:07.782] flashing tool "wrx02" loaded.
[19:22:07.783] flashing tool "wrx04" loaded.
[19:22:07.783] flashing tool "sti04" loaded.
[19:22:07.783] flashing tool "sti05" loaded.
[19:22:07.783] flashing tool "mitsukernel" loaded.
[19:22:07.783] flashing tool "mitsukernelocp" loaded.
[19:22:07.783] flashing tool "mitsubootloader" loaded.
[19:22:07.783] flashing tool "shbootmode" loaded.
[19:22:07.784] flashing tool "shaudmode" loaded.
[19:22:07.785] flashing tool "subarucan" loaded.
[19:22:07.785] flashing tool "mitsucan" loaded.
[19:22:44.923] J2534 API Version: 04.04
[19:22:44.923] J2534 DLL Version: 0.50.2598 (DEBUG) Jun 26 2009 15:02:29
[19:22:44.923] Device Firmware Version: 1.07.2597
[19:22:48.691] sending init sequence 1 (0001)
[19:22:51.968] sending init sequence 1 (0003)
[19:22:55.245] sending init sequence 1 (FFFF)
[19:22:57.962] no response to any known code
[19:22:57.963] interface close
No me a pasado todavia pero dices que puede ser posible que al tratar de leer una ecu me encuentre con que el tunner anterior le puso un bloqueo? Aqui salen publicaciones sobre como hacerlo? Recien me registre en el foro hoy. Me parece todo super interesante
Old Jul 2, 2025 | 05:30 PM
  #113
evogaragebrazil's Avatar
please help with ROM image of my lancer manual 2014
Hi everyone, i'm trying to read the ROM file of my lancer manual that i setup a turbo and i need to rewrite the ECU, but it keeps giving me the message of unknown ROM image
What do i do, pleasseeee
wreckleford
May 27, 2016 08:06 PM
lonestarevo83
Jul 15, 2011 07:20 PM
Tbtalon94
Nov 2, 2010 07:52 AM
rolly1818
Nov 25, 2008 05:09 AM
