Can't Read or Write ECU
Old Apr 9, 2010 | 09:20 PM
bboy_RES's Avatar
Still Can't Read or Write ECU
i still can't read or write onto my ECU. here's what i tried so far.
Battery/Voltage: I fully charged my battery and tried to read/write my ECU. no luck.
Software/Cable: I tried using my laptop and cable on a friend's Evo and it worked which obviously means that the software and cable are functioning properly.
ECU: I bought a new ECU the today and installed it on my car, but it still won't let me read/write anything.
Init Port (White Connector): how many wires should the white connector have? i noticed that the connector in the car has one wire/one pin on it, while the plug on the cable itself has three wires on it. is that normal?
does anyone have any other ideas? am i overlooking anything? i'm stressing out right now.
Old Apr 9, 2010 | 11:32 PM
GregM's Avatar
Try ecu unlocker software, although I would have thought changing ecu would have fixed the problem.
Has it worked before, or have you never tried doing a read/write?
Old Apr 10, 2010 | 10:15 AM
bboy_RES's Avatar
i forgot to add that i've tried ECU Unlocker already. i believe i found my problem though. i'll let you guys know if i fix it.
Old Apr 10, 2010 | 06:04 PM
bboy_RES's Avatar
fixed it. fuse #8 under the hood kept blowing.
Broke4speed
Aug 6, 2017 07:57 PM
jeri534
Oct 22, 2009 09:50 PM
mt057
May 12, 2009 05:12 AM
silver_evo
Apr 2, 2009 09:40 PM
evolved lancer
Dec 21, 2008 03:01 PM
