Having trouble reading ECU with Ecuflash
Old Oct 21, 2009 | 11:50 PM
jeri534's Avatar
Having trouble reading/writing to ECU
Im running ECU Flash 1.29a (because I have the older cable), and it seems I can only seem to read/write to my ECU if my engine is running, it will shut it off and most of the time it works, if I just try it with Engine Off, Ignition on it almost never works, it will attempt to send the 3 codes and it just times out and gives me an error...
Has anyone had this issue before?
thanks
Old Oct 21, 2009 | 11:56 PM
tephra's Avatar
battery...
u need to have it fully charged.
also you can contact tactrix/evoscan for an update to the cable to allow it to work with newer ecuflash version
Old Oct 22, 2009 | 12:00 AM
jeri534's Avatar
Is that all it is? Battery voltage? Ill put a battery maintainer on it tomorrow and see if it works with that.
Thanks for the quick reply.
Old Oct 22, 2009 | 08:28 PM
codgi's Avatar
Originally Posted by tephra
battery...
+1. To the OP, is this a mini battery or just an old IX OEM battery? Those two situations seem to exacerbate it more on the IXs.
Old Oct 22, 2009 | 09:50 PM
jeri534's Avatar
oem IX battery
is there a certain voltage ECUflash has to see before it will continue on with reading/writing to the ECU?
Danner
Aug 13, 2011 11:13 AM
dudemeister
Lancer Troubleshooting
Jan 18, 2011 10:51 PM
electricman
May 25, 2009 03:00 PM
Alchemist
Lancer Engine Tech
57
Aug 28, 2005 09:36 PM
k270kmh
50
Aug 28, 2005 11:03 AM
