Help needed, tuner wont reply and my tune is all over the place.
tscompusa@gmail.com - make sure you use the same battery voltage settings that created that 12.2 a/f with my altered map.
also the load in your logs is non existent.. the 2byte load is way wrong. it seems you're not monitoring the proper MUT address anymore.
Thats ok tho i can still edit your WOT a/f without seeing the load...... the map should be flat at the higher loads so it shouldnt be a problem.
TScomp, youre a nice guy for helping him out. Question, when you set up new injectors and you do the idle log for what 20 min? Then do a cruise log in 4th gear at 60 mph for another 20 min? Then what is it you adjust the batt. voltage latencies or the scaling? This area of the tune needs a detailed how to for us beginners!
DormantBeast
21
Apr 5, 2011 03:59 PM
