Evo9 JDM won't read
Old Apr 16, 2010 | 11:01 PM
evo9_jdm's Avatar
Evo9 JDM won't read
Hello,
To begin I have a JDM Evo 9 GSR from Japan this is the info I have on my ecu RA186501R1 it is a ralliart Ecu I downloaded Ecuflash v1.42 also ecu unlocker v1.1 and I have the openport 2.0. First I am opening ecu unlocker and then Ecuflash with ignition on I am trying to read my rom and it starts for 15 sec and error I am doing everything good but it just wont let me read my rom I have been trying everthing for 2 day now and nothing can any one help me
[00:20:23.046] J2534 API Version: 04.04
[00:20:23.046] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[00:20:23.046] Device Firmware Version: 1.10.2658
[00:20:25.250] sending init sequence 1 (0001)
[00:20:28.500] sending init sequence 1 (0003)
[00:20:31.750] sending init sequence 1 (FFFF)
[00:20:35.000] sending init sequence 1 (F0F0)
[00:20:37.703] no response to any known code
[00:20:37.703] interface close
This is what ecuflash is doing. I have evoscan and it runs perfect with no issues its perfect. I am running windows XP hope some one can help me ?
I would like to add I never uploaded a rom into my ecu yet if it makes a difference I would like to download my rom and edit because it its a ralliart rom I am running 26psi with no problems for 1 year now and drag time is 11.92 sec 1/4 so I really need to see this rom AFR is 10.9 to 11.4. and engine is stock no pistons kits or anything for now
Old Apr 17, 2010 | 04:28 AM
evonut270's Avatar
Is the flash plug wire connected?have you opened ecu unlocker before opening ecuflash
Old Apr 17, 2010 | 04:43 AM
evo9_jdm's Avatar
Yes openport 2.0 is conected under the steering to my laptop ignition is on. Yes first I opened ecu unlocker and then I opened ecuflash its starts to read and then stops with that error. I tried to connect for 7 hours yesterday I even had windows 7 installed and I removed it to try windows XP but still nothing. I even removed all software and installed ecuflash with ignition on because I found a thread saying that you should install with ignition on but nothing I have net 2.0 installed and even net 3.0 firmware because for most people that solves the issue but its not working for me.
Also I have a question remember I am a beginner how do you know what your Evo Id is ? Is it the part number on the ECU or does Ecuflash give it to you ?
I have been reading threads for 2 weeks absorbing info to understand more about this cool software for evo's but I cant figure out what my id is.
Old Apr 17, 2010 | 07:54 AM
wip's Avatar
wip
You never said anything about the battery voltage?
Have you taken it out for a run then tried to read it?
Old Apr 17, 2010 | 11:08 AM
evonut270's Avatar
Have you connected both op2.0 and the White flash plug?
Old Apr 17, 2010 | 11:38 AM
evo9_jdm's Avatar
Battery voltage is not low I have a new battery and I also charged it to be sure so this should not be the issue. I have read many threads like you are saying it wont read if the battery is low so I made sure that its not.
My evo has been sitting in my garage for 2 days I did not give it a run first if it matters.
I only have op2.0 plug I do not have flash plug wire do I need it to read the ECU with ECUflash ? I am not trying to flash it with a new rom .
Old Apr 17, 2010 | 02:50 PM
evonut270's Avatar
You can't read or write a rom without the flash plug so your going to need to buy one
Old Apr 18, 2010 | 05:16 AM
evo9_jdm's Avatar
I also ordered the flash plug last week so I should receive it very soon. I thought that evo 9 did not need the flash plug for some reason I think I saw a video on you tube saying that only earlier version of evo's need the flash plug. I will post as soon as I get it but it should work fine.
thanks allot mate
MR Turco
Jul 2, 2025 05:30 PM
evoscan
52
Jun 20, 2017 01:46 AM
AWDTFTW
Feb 8, 2014 02:17 PM
JPSR20DET
May 12, 2011 05:58 PM
