using tephra v7 map switching as meth failsafe
Old Apr 25, 2010 | 02:46 PM
EvoJoeIX's Avatar
can anybody please explain what i need to use the map switching as a meth failsafe? im running a boost cut set-up right now as a failsafe, but i wanna run a 25psi wastegate actuator. so my thing is if it cuts my boost to wastegate pressure, it will only drop to 25psi and if meth stops spraying, im sure it would still cause damage. so i wanna make it so i would switch to a different map if it stops spraying. im not sure what i need to do this or how to set-up it. im looking for some help here. id appreciate some input.
thanks in advance guys
Old Apr 26, 2010 | 01:39 AM
burnzy's Avatar
have a read it's all on here, otherwise if you have hfs-3 or hfs-6 ther eis an 5v output line that you would put into pin 64 and turn on adcf01 map switching
clockworktoy
Oct 9, 2012 09:23 PM
Andrew@AMS
Automotosports - Illinois
Sep 18, 2012 07:01 AM
STi2EvoX
Nov 2, 2009 06:30 PM
EvoJoeIX
Jul 1, 2008 01:21 PM
mfr122887
Sep 25, 2007 10:36 AM
