which parameter need to log to use with maptracer
Old May 14, 2010 | 05:03 AM
ms_logging's Avatar
hi. my car is evo 5 jdm i can read and write flash normaly. as i understood to log knock i must log rpm , knock sum and some 3-rd parameter (something meens load) to have posibility using maptracer. my question is which one i must log ? thanks ! p.s when i am trying to log load calculated it always stays 0. please help
Old May 14, 2010 | 05:18 AM
hediki12's Avatar
when tuning WOT i use TPS (to know when i floor it), rpm, knock, afr, timing, load . i only use idc and ipw when i turn up the boost to make sure im not on the edge of the limits of the injectors.
map tracer for evoscan 2.6 would like load calc logged to display a trace. but since its limited to i think 160 load? then you need 2byte or 1byte load to read higher
Old May 14, 2010 | 08:07 AM
ms_logging's Avatar
ok thanks for reply!. as you sad i must log load 1byte but i can not make this working. i think need to edit rom to add abylity log load1byte (tephra mod i gues) but how to do ic jus coping xml files to xml folder does not helped me. need advice.
Old May 14, 2010 | 08:09 AM
hediki12's Avatar
your running a ev0 8 ecu in a evo 5? which rom are you using?
Old May 14, 2010 | 08:40 AM
ms_logging's Avatar
no i am runing stock evo5 ecu with stock evo 5 rom . case id : mr4200403 internal id :22580007
Old May 14, 2010 | 08:46 AM
hediki12's Avatar
wow yea i know nothing about that one i was hoping it was a evo8 ecu. ill look around and let you know what i find tho hopefully someone can help.
Old May 15, 2010 | 01:56 AM
ms_logging's Avatar
please some one help me to make map tracer work...
Old May 15, 2010 | 02:00 AM
hediki12's Avatar
Evoscan 2.6 needs rpm and load calc those are the only 2 parameters it need 2 enable map tracer. Evo scan 2.7 need I beleave 2byte rpm and 2byte load I think...
Old May 15, 2010 | 02:29 AM
ms_logging's Avatar
but how to enable 2 byte load logging .
Old May 15, 2010 | 03:43 AM
hediki12's Avatar
Pm ceddy . He specializes in the older ecus so may be he can whip up a code for you of basic mods. So far I've searched and can't find any disassemblies for pre evo7. But hopefully some one can help.
Old May 15, 2010 | 05:09 AM
ms_logging's Avatar
thanks for helping me ! i will attach my rom maybe someone can patch it to give me posibility of logging load propertly .
File Type: zip
Old May 17, 2010 | 05:17 AM
ms_logging's Avatar
any ideas ?
Old May 17, 2010 | 06:11 AM
Ceddy's Avatar
Only newer versions of EvoScan work with H8(Evo5-6.5) MapTracer.
Think version 2.7.0031 and above work.
Any of the Loads will work, but "ECULoad" maxes out at 160 (about 9 psi).
You will need to add a 2Byte Load.
For 22580007 the addresses for 2Byte Load is F196 and F197.
In MUT Table change MUT00 to F196 and MUT01 to F197.
Then log "Load MUT 2Byte Mod" in EvoScan.
2Byte Load has no upper limit.
http://geekmapped.com/ is a good forum to check out, they specialized in older Evo ecus.
And you may want to switch to a rom with more support.
Old May 20, 2010 | 01:08 PM
ms_logging's Avatar
thanks ! but now i got another problem. evoscan 2.6 logging duty cycle normal but evoscan 2.7 always idicates 0. pulse wight indicated normaly.
Old May 20, 2010 | 02:07 PM
leecavturbo's Avatar
1byte will work too
in evoscan right click on load1byte and click edit data item
where it says Log reference: Load1b change it to Loadcalc
now when you do a log of 1 byte map tracer will find it by looking for loadcalc which you just called
or do the same with 2byte if your logging that
