Need help
Old May 17, 2010 | 09:31 PM
EvowagonIX's Avatar
Need help
Well i logged my evo before and an after installing a hard pipe and cobb tuning sf intake on my 9. Need help in analyzing it and etc.
How can i locate the logs to upload them?
Old May 18, 2010 | 08:25 AM
golruss's Avatar
Did u use Evoscan to log? If so in winXP right click Start, explore, program files, look for evoscan, right click and look for Saved data logs, open and it should be there.
Old May 18, 2010 | 08:33 AM
EvowagonIX's Avatar
Used vista, and also i found the folder, but the logs not in it, but when i open evoscan and use analyze i see the logs.
Old May 18, 2010 | 08:39 AM
evo8426's Avatar
go to the "logging" tab, then click on "explorer - open csv log file folder" it should open up where you have all the logs saved
Old May 18, 2010 | 10:01 AM
EvowagonIX's Avatar
Doesn't show them up in there either, only the two sample logs. I only see the logs that I did when I click analyze.
Old May 18, 2010 | 10:12 AM
evo8426's Avatar
how many versions of evoscan are installed on the computer? ive noticed if i have an old copy and a newer copy i open up the wrong evoscan folder when the logs are actually in a different location. when you play back a log before you select one try and look at the drop down menu to see what all subfolders it has to go through to get to the log. if that doesnt work then you could try searching the computer for "EvoScanDataLog" and see if it will bring up all the logs you have done.
Old May 18, 2010 | 12:54 PM
EvowagonIX's Avatar
did all a that, only finding the shortcuts for the logs, and when i click on them, its saying missing shortcut.
Old May 18, 2010 | 01:15 PM
EvowagonIX's Avatar
Found them. first one was before and the two last ones were after the intake was installed.
File Type: zip
Old May 18, 2010 | 06:01 PM
evo8426's Avatar
you need a wideband so adjustments can be made for the car especially since youve got an intake and im not really sure what exactly your mods are. not sure what hard pipe youre talking about? or what a sf intake is
Old May 18, 2010 | 06:07 PM
evo8426's Avatar
additionally you need to do several 3rd gear pulls from 2500-7000rpm on a straight and flat road and not just part throttle driving. the logs you took dont have any useful information to be pulled out of them to help you out any.
Old May 18, 2010 | 09:03 PM
EvowagonIX's Avatar
the last two where full throttle. after the cobb tuning sf intake with aem hard intake pipe.
EvowagonIX's Avatar
Also mods are 2.75" downpipe, 3.5" exhaust. everything else stock.
Old May 18, 2010 | 09:54 PM
evo8426's Avatar
weird, your TPS never was at 100% also your 2byte load is way off and needs to be fixed because it tells what cells you are hitting in the fuel and timing maps. youre not running tephra v7 rom by any chance are you? if you are then i can send you my data xml for evoscan so you can log some very basic items
Old May 18, 2010 | 10:16 PM
EvowagonIX's Avatar
No, im not, its the stock rom, remember its a JDM Evo IX wagon.
jakgal04
Mar 28, 2016 08:16 AM
evokid511
Oct 29, 2009 07:08 PM
RedLanEVO
Jan 29, 2009 08:58 AM
EatSleepBoost
Aug 21, 2008 08:42 PM
Evo Singh
Jan 9, 2007 10:09 PM
