Help for my RS from the experts:)
We've been needing user defined outputs for a while now. To fit a variety of different uses I think this would work best. Allow the user to enter the output they would like to hijack in the stock code. Depending on the car setup you may not use some of the stock outputs (EGR, secondary fuel pump, cooling fan, etc...). Then allow the user to determine when this output is on or off using 2d tables of X vs output state. The variables of X would be RPM, TPS, and load. When all three tables are true, the output is on. It would look like this:
RPM state
500 0
1000 1
1500 1
2000 1
etc.......
TPS state
10 0
20 0
30 0
40 1
50 1
etc....
load state
0 0
20 0
40 1
60 1
80 0
100 0
etc...
Thus the output would be active when RPM is greater than 500, tps is more than 40%, and load is between 40-60%.
This would work for david right now and for me in the future so that I have a way to activate nitrous on my auto car.
RPM state
500 0
1000 1
1500 1
2000 1
etc.......
TPS state
10 0
20 0
30 0
40 1
50 1
etc....
load state
0 0
20 0
40 1
60 1
80 0
100 0
etc...
EcuFlash doesn't offer a table with multiple scalings, so unfortunately I have to use six tables.
There are six windows for RPM, TPS, Load, Speed, Knock, and Boost. You must be in the window for all six, for activation.
Stock or Windowed Control is by a flag byte, that allows Inversion of output also.
Sorry, man I have been so freaking busy it's unreal, busier than I've been in years. Shop is swamped, we are all doing more to keep up.
0xdead, something like you descibed seemed to be best, if that is able to be used for multiple outputs.
Roadspike, I'd really like to program this stuff in the actual ECU. The fan should be the easiest thing to take care of. Water pump/fuel pump needs figured out.
Thank you all for looking into it.
BTW, I've tuned a few speed density cars, I just haven't been posting many results lately. I get tired of the grief on the forums and it's driving me away.
Dead or Ceddy from a programming standpoint do you just hook into the ioport subroutine and override like the CEL flash or something different, still learning here.
Most of the solenoids can be hooked in the Duty Cycle Output sub (The one that counts to 0x30).
Found that easily in the 94170015 rom version looks like there are a bunch of solenoid controls happening here egr, wastegate duty, and a few more.
IF, IF, someone here has a solution and can build a ROM, I can give you more exact details on what I am doing and triggering. I'd gladly just pay someone to build what I need and send me the base file that will function.
I will run speed density, 5 bar AEM map sensor and AEM/GM AIT.
The Haltech runs DAMN good on my car but I'd like to give the stock ECU a shot and see how well it will work. My opinion on it sure has changed in the last few years and we've put out a lot of cars making great power on it.
Thanks everyone.
Thanks everyone.
I wouldn't mind writing the patch I really have only one question to the mod gods.
Since all these signals are pwm it looks highly like the code itself does the switching of the on and off state via bitwise signal. So basically can i just switch it to permanent on or off status?
Got about three "duty" variables i need to figure out
Alread know egr, evap, and wastegate
There are 4 unknown pwm signals but they get ignored if FAA bit 6 is set to 0.
Edit:
Discovered what they were now.
All 4 are the heater circuits of the o2 sensors 2 are just unused because they are meant for a v6 setup it appears.
Still 2 unknown pwm signals to determine hopefully one is the fpr which all i need to begin making a patch.
Edit:
MUT_9B bit #7 is FPS flag on H8s, most likely same on SHs.
Actuator_0 bit #3, is another way to find the FPS routine.
For item order in the PWM sub, I have:
EGR
Purge
Front O2 Heater
Secondary Front O2 Heater
Rear O2 Heater
Secondary Rear O2 Heater
Wastegate
Skipped - Unknown
Skipped - Unknown
The FPS most likely isn't PWM. On H8 ecus it isn't, and I doubt they changed it for the SH ecus.
EGR
Purge
Front O2 Heater
Rear O2 Heater
Wastegate
Skipped - Unknown
Skipped - Unknown
EGR
Purge
Front O2 Heater
Rear O2 Heater
Wastegate
Skipped - Unknown
Skipped - Unknown
Edit:
Ok so i think I found the actuator routine but i have a few questions.
Bit 3 as in h'0x4 or as in h'0x8 i can never tell if people even programmers start with 0 or not.
Didn't find any references to actuator_0 but mut 9b was of course easy enough to track back.
Current rom 94170015
PWM sub @ 0xB1FE
Actuator Sub @ 0xAEB4
It looks like things are in a little different order and there are fewer PWM outputs in 96530006. If somebody can tell me if I got this right, it would be awesome.
Actuator Sub is at AC94
PWM Sub is at B032
The order of the PWM subs looks to be:
EGR
Purge
Wastegate
Front O2 Heater
2nd Front O2 Heater
Rear O2 Heater
2nd Rear O2 Heater
PWM Sub is at B032
EGR
Purge
Wastegate
Front O2 Heater
2nd Front O2 Heater
Rear O2 Heater
2nd Rear O2 Heater
PWM Sub is at B032
EGR
Purge
Wastegate
Front O2 Heater
2nd Front O2 Heater
Rear O2 Heater
2nd Rear O2 Heater
PWM Sub is at B032
EGR
Purge
Wastegate
Front O2 Heater
2nd Front O2 Heater
Rear O2 Heater
2nd Rear O2 Heater
Those are the same as the spots i found in the 94170015 rom.
Think I may have discovered in a different way the actuator code that does the fuel pressure solenoid plus a few others like fuel pump etc.
94170015 ram address FFFF8CCA
Basically reversing the mut command d6 for the fuel pressure solenoid to get to this location. It may not even be right but perhaps i'm on the right track
Code location I'm guessing its at: 0x1EFF4
Mut Request Location:
0x8C3C
.Code location I'm guessing its at: 0x1EFF4
0x8C3C
