V7 PSI based boost control
Old Aug 17, 2011 | 04:10 PM
  #46
dparrish's Avatar
Read post #3 on https://www.evolutionm.net/forums/ec...t-control.html
Old Apr 18, 2012 | 07:49 PM
  #47
CRONZ305's Avatar
anyone have a peak 22-23 psi drop to 20psi by redline??? evo 9??
Old Apr 19, 2012 | 12:16 AM
  #48
Boosted Tuning's Avatar
Every car uses different WGDC amounts, so each ECU boost system has to be tuned for each car. You cant just use someone else's settings..
Old Apr 19, 2012 | 06:15 AM
  #49
Raptord's Avatar
This.
That being said, with my grimmspeed 3-port I run roughly 65%WGDC at 3.5k, tappering slowly up to 68 by 6k, then up to 71% at 7k for a similar boost curve to what you're talking about.
Old Apr 19, 2012 | 08:45 AM
  #50
Ian0611's Avatar
Originally Posted by Raptord
This.
Just to drive home the point here and back up what has already been said... I'm also on a Grimmspeed and I run about 62% WGDC through the whole rev range which has me peaking around 28psi at 4k, tapering to about 23 psi at 7K. So yeah, it's definitely different for each car and set-up.
Old Apr 19, 2012 | 09:35 AM
  #51
CRONZ305's Avatar
I didn't plan on using someone's settings. I know better than to do that. I just wanted to get an idea.
Old Jun 24, 2012 | 04:42 PM
  #52
GTijoejoe's Avatar
I'm still slightly confused by the BEC tables for PSI based control. What should the values be? My default values were all 14.5? seems strange.
Can anyone post some more examples of there boost control tables?
Old Jun 24, 2012 | 05:28 PM
  #53
Raptord's Avatar
BEC is the error correction table, and the values shouldn't all be 14.5. You sure you had the right table?
Old Jun 24, 2012 | 07:08 PM
  #54
GTijoejoe's Avatar
Yeah, it was strange....
OK read carefully please as I don't want to confuse you lol
...cause here is the deal, I spend like 3 hours today dialing in my WGDC table to get this curve. 28psi max without direct boost control (my correction in my logs is 0, all 100% WGDC)
This is a 3rd gear pull btw, 4th gear holds more boost up top.
Than I came across this thread and looking at the two previous posts about the tables I was like WTF? my BEC is all 14.5... so I started to change some tables and this is what I currently have, not uploaded yet..... basically used some of the values from the other posted tables. My boost adder is basically 14.7+10= 24.7, and than my PSI table is setup to run 28psi. My WGDC table should be very very close I would think as I spent a while on it today.
Let me know what you think.... am I on the right track here?
Old Jun 24, 2012 | 07:26 PM
  #55
Raptord's Avatar
Joe, I would set your low-rpm BDE tables to the max boost you want to run. Otherwise if your turbo spools faster than what you have there, it'll start dropping WGDC, which you obviously don't want during spoolup.
Also, on my car I set max upward correction to 0 across the board to keep from seeing small boost spikes as the turbo finishes spooling and you're just under your target.
My 2¢!
Old Jun 25, 2012 | 07:01 PM
  #56
GTijoejoe's Avatar
My 2¢!
Cool man, thanks for your input.... my BDE was set from logs of my pulls ... basically matches my spool almost, the table is slightly higher than my spool.. but your advice wouldn't hurt. Thanks for the input.
Old Jun 25, 2012 | 07:12 PM
  #57
Benja's Avatar
Anyone able to port PSI based boost control to 90550701?
Old Jun 25, 2012 | 09:36 PM
  #58
07EvoIX's Avatar
can anyone adivse if PSI/Boost Error is MAP dependant?
Reason i ask is cause i have found 3 EvoScan formulas for Boost Error here and not sure which one is correct?
From the direct boost thread, mrfred has the formula as 0.0241*x-3.087. Thats from 2007. But then in the below thread from 2011 there are an additional 2 formulas.
https://www.evolutionm.net/forums/ev...a-evoscan.html
whats the correct one?
cheers
Old Jun 25, 2012 | 10:36 PM
  #59
Benja's Avatar
I would imagine so Fadee.
Different size map sensors produce different output voltages at each boost level.
Old Jun 26, 2012 | 12:01 AM
  #60
07EvoIX's Avatar
i guess my next question is...
what is the PSI Error formula for a GM 3bar MAP sensor?
OR
how can i determine what the formula would be?
cheers
