TephraXMOD V1
Old Jul 5, 2010 | 12:14 AM
  #166
phughe03's Avatar
Hi Tephra,
53040013 would be awesome but I haven't even found the right .xml yet ?
Cheers
Pete
Old Jul 5, 2010 | 08:39 AM
  #167
Kasander's Avatar
1- 53600010 - USDM RA 2009
2- 54060007 - PR GSR 2009
3- 54070007 - PR MR 2009
Maybe the 2 PR are not the latest version of available rom but got a few customer with good setup that have issues due to the gaz available when they travel and 2 maps would come in handy.
As before, donation will be sent your way when those are installed.
thanks D
Old Jul 6, 2010 | 06:58 AM
  #168
rober_x's Avatar
hi tephra,
I'm waiting for 53040007, do you have anything..hehe...
you´re the best!!!!!!!!!!!
Old Jul 6, 2010 | 04:52 PM
  #169
tephra's Avatar
^ upgrade to 53040010
Old Jul 6, 2010 | 05:00 PM
  #170
bulhas's Avatar
is their multiple ecu id's for 2010 RA's i have 55590006
Old Jul 6, 2010 | 05:46 PM
  #171
tephra's Avatar
55590007 is the latest afaik... bryan is testing the tephraxmod for that rom as we speak
Old Jul 6, 2010 | 06:09 PM
  #172
bulhas's Avatar
awesome
Old Jul 6, 2010 | 06:23 PM
  #173
EvoX2NR's Avatar
Hey Tephra thanks for making this mod... it definitely helps with running E85. One issue that I am having with my 08 USDM GSR is I am getting a code for the fuel temp sensor high input. Do I need to throw in the 250ohm resistor and ground the wire if I am using the cruise control switch for map switching to overcome this issue?
Old Jul 6, 2010 | 06:58 PM
  #174
burnzy's Avatar
where can we get a pin to wire in 115 input on the adm ecus?
Old Jul 7, 2010 | 05:25 PM
  #175
EvoXCR's Avatar
Since I have an RS (with no Cruise Control) I bought the steering wheel switches for the Cruise Control, however it is not working, neither for the Cruise Control nor the map switching. Do you guys know what has to be done to activate it? Hope is not a dealer activation...
Thanks!
Old Jul 7, 2010 | 05:38 PM
  #176
tephra's Avatar
it should work.
i am assuming you have checked the wiring back to the ECU is there?
Old Jul 7, 2010 | 06:47 PM
  #177
burnzy's Avatar
do evo 9 pins fit evo x?
Old Jul 7, 2010 | 06:49 PM
  #178
tephra's Avatar
no...
I just used some oversize wire and stuck it into the right hole on the plug...
then ziptied the other side to the rest of the cables...
Old Jul 7, 2010 | 07:05 PM
  #179
EvoX2NR's Avatar
Would you happen to have any insight on this:
Old Jul 7, 2010 | 07:07 PM
  #180
tephra's Avatar
hrmm...
if your using cruise control AND you havn't cut the fuel temp sensor then you should be fine.
can you give me the DTC code number?
