TephraXMOD V1
Old Jul 7, 2010 | 07:09 PM
  #181
EvoX2NR's Avatar
P0183
Old Jul 7, 2010 | 07:12 PM
  #182
tephra's Avatar
... and did you cut the fuel tank temp sensor wire?
Old Jul 7, 2010 | 07:16 PM
  #183
EvoX2NR's Avatar
I tried cutting it and the code came back right away.
Old Jul 7, 2010 | 07:20 PM
  #184
tephra's Avatar
ok well your ONLY meant to cut that wire IF your using altmap master mode 4 (Resistor ADC)...
reconnect the wire, and clear the code... it shouldn't come back...
Old Jul 7, 2010 | 07:21 PM
  #185
EvoX2NR's Avatar
LOL, I cut it in the first place because I was trying to make it go away.
Old Jul 7, 2010 | 07:22 PM
  #186
tephra's Avatar
ok now that you have cut it - can you try running altmap master = 4 and see if it comes back (after you clear it)
if thats ok, then reconnect the wire and switch back to altmap master = 2 (cruise control)
Old Jul 7, 2010 | 07:26 PM
  #187
EvoX2NR's Avatar
I will once I get access to a cable. Unfortunately I wasn't the person who put this on the ecu. I am going to give the resistor a shot tomorrow and see what happens...
Old Jul 7, 2010 | 07:34 PM
  #188
tephra's Avatar
if your NOT using Resistor ADC mode (altmap master = 4) then just reconnect the wire... its probably better your ECU knows what the fuel tank temperature is.
the 250ohm resistor will be too LOW anyways, you should be using 5k...
but reconnect it and then go from there
Old Jul 7, 2010 | 08:16 PM
  #189
EvoXCR's Avatar
I was checking the wiring when I saw Tephra's post... no lines from C130 connector to the ECU. Had to build the harness. It's now working for turning the cruise control on/off and switching between maps but the cruise control itself is not working.
Any thoughts?
Thanks
Old Jul 7, 2010 | 10:39 PM
  #190
Golden's Avatar
Code is probably not in your ROM. Or it's disabled.
Old Jul 7, 2010 | 10:44 PM
  #191
tephra's Avatar
there might be a pbit or something to enable cruise...
ill have a look when i can
Old Jul 8, 2010 | 08:22 AM
  #192
EvoXCR's Avatar
While rechecking there seems to be no line from the brake pedal to the ECU. Will check on that and keep you guys posted.
Thanks for your help!
Old Jul 9, 2010 | 04:27 PM
  #193
GST Motorsports's Avatar
55590007 is the latest afaik... bryan is testing the tephraxmod for that rom as we speak
Tested, map switching works. Only problem is the 2010 RA physically has no IC spray icon to blink when on alt map.
(The RA has a different cluster then the Evo)
Tephra, you haz email.
- Bryan
Old Jul 9, 2010 | 04:36 PM
  #194
HB Speed's Avatar
- Bryan
Made 375 whp on 91 on dom2 with this last night!!
Old Jul 9, 2010 | 05:24 PM
  #195
tephra's Avatar
yep im looking into it..
