TephraXMOD V1
Old Nov 13, 2010 | 01:14 AM
  #436
kozmic27's Avatar
Originally Posted by GST Motorsports
Map 6 of the different maps to each gear... gear based tunes! haha
- Bryan
That would be the ****.
Old Nov 13, 2010 | 06:33 AM
  #437
tsitalon1's Avatar
Originally Posted by tephra
ok so how important is having gear based MIVEC control?
do you want full gear control, ie 1/2/3/4/5/6 maps?
or just high/low with customizable crossover (like boost)
me personally probably wouldn't use it, but then I don't have an FPRed
Do you need 9 different MIVEC altmaps?
I can only speak of my experience with the green. The green only really needs High/low as gears 1-3 (on a GSR) seem to be able to handle my mivec just fine.
Sometimes 4th and 5th aren't to happy so my vote is high/low.
Gear based tunes (1-6) seems good, but I am also thinking of the tuning headaches it could cause, having to check/change all 6 tunes to make a global change.
Old Nov 15, 2010 | 02:17 PM
  #438
hawaiian_evo's Avatar
For the resistor on the 5v switch will a .5 watt 220 ohm be good enough? The store I went to only got .5 270 ohm or 220 ohm
Old Nov 15, 2010 | 02:26 PM
  #439
tephra's Avatar
yeah that will be fine... you may have to adjust the cutover voltage a little...
Old Nov 15, 2010 | 03:42 PM
  #440
sorry not to sound like a newb i just don't want to fry my ecu but how much do I adjust the voltage by?
Old Nov 15, 2010 | 04:00 PM
  #441
tephra's Avatar
you wont fry the ECU
get the 270 Ohm, I higher resistance means the ECU see less current/voltage.
Once you have it hooked up I can tell you what to log so you can set the cutover voltage
Old Nov 16, 2010 | 09:05 PM
  #442
Ok so for my hfs6 the yellow harness I got the white wire grounded and the black wire running to the 270 ohm resistor/ black and white wire . Now how do I log the volts to see what I have to adj.
Mahalo
Old Nov 16, 2010 | 09:14 PM
  #443
tephra's Avatar
52680122?
Old Nov 16, 2010 | 09:25 PM
  #444
52680122?
Yes
Old Nov 16, 2010 | 09:28 PM
  #445
tephra's Avatar
log 0x805009 (just 1 byte)
Eval = x*5/255
Then turn the HFS guage on and off - you should see the value flick up and down.
report back with the numbers for both
Old Nov 16, 2010 | 09:40 PM
  #446
Ok ill try it...also tephra do u mind pming me your email add incase I got further questions ??
Mahalo for all your help
Old Nov 16, 2010 | 09:59 PM
  #447
tephra's Avatar
its myforumname -> gmail dot com
Old Nov 17, 2010 | 03:20 PM
  #448
Richard L's Avatar
tephra,
I would like to annouce...
The latest HFS3-v2 has incorporated an inline resistor on board so map switch for the X is now only a one wire affair.
Richard
Old Nov 17, 2010 | 04:24 PM
  #449
tephra's Avatar
awesome...
that should make things easier..
Old Nov 18, 2010 | 12:46 AM
  #450
Originally Posted by Richard L
tephra,
Richard
wait im confused. I have the hfs6 do i still need to follow the resistor instructions on the 1st page?
